Old 03-13-2013, 01:03 PM   #1
Love My Sunseeker
DXSMac's Avatar
Surge Protector already in RV???
Last night I had a problem with my electricity, I have a surge protector on, and it was kicking in and preventing me from having electricity.
I called a Certified RV Mobile Tech. The Tech recommends that I take the surge protector off (It's the EXPEN$IVE one from Camping World), and see if I have problems. The Tech said that I have "some" surge protection already built in (I have a 2013 Sunseeker) so removing the protector shouldn't be a problem. The maintenance guy at the RV park has already checked the pole and found no problem.
My surge proctor is kicking off at 124 volts. According to Camping World, it should go up to 132.
Do I have such a thing as "some" surge protection in my 2013 Sunseeker? I find this hard to believe.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 03-13-2013, 01:15 PM   #2
Dave_Monica's Avatar
I'm not familiar with your exact surge protector but doesn't it display a fault code when it trips?
Dave
Old 03-13-2013, 01:53 PM   #3
Not great advice from that tech. Oh sure, take out the device that is potentially protecting your RV from damage and see if it gets damaged.
The Progressive Industries protectors display a "current" error code and a "previous" error code so you can tell what's going on. Camping World does sell those, but they don't seem to advertise them as much.
Old 03-13-2013, 01:58 PM   #4
More advice. I think you should call the manufacturer. They have ways to diagnose over the phone. If it's the Progressive Industries unit, it has a lifetime warranty (at least new ones do).
Old 03-13-2013, 04:17 PM   #5
Love My Sunseeker
DXSMac's Avatar
Dave
If it is supposed to, I saw nothing. All I saw on the readout was a green light (indicating power) and it said "124 volts ZERO amps."
It's not supposed to kick off at 124 volts. The RV tech said that it's been raining a lot here, and it's possible the rain got inside the surge protector and corroded part of it.
Camping World told me that I have to ship it to the manufacturer (TRC = Technology Research Corporation, sounds like a fly by night operation).
Old 03-13-2013, 04:34 PM   #6
Dude, if you'd give us the model number we might be able to tell you more. If it's what I'm guessing it is, it's designed to kick off for lots of reasons other than just high voltage. Hopefully the tech checked those those things. That company gives a 1-year warranty, although I've heard a story or two of them taking care of people long after that. CALL THEM.
Old 03-13-2013, 05:39 PM   #7
Love My Sunseeker
DXSMac's Avatar
My surge protector is model 34730 for 30 amps. My Sunseeker is Model 3170. I find it hard to believe that there are "built in surge protectors" in my RV. I don't like not being hooked up with a surge protector, those things have saved my butt a few times.
I left a message at the contact number for TRC. Apparently, they are on the east coast.
(by the way, I'm a "dudess" or a "ma'am" whichever you want to use....
Old 03-13-2013, 05:45 PM   #8
Witch Doctor's Avatar
I have never heard of unit coming with a surge protector already installed by the factory, but I'm not sure about a sunseaker either. Did you check your ground faults inside the unit. That will stop any AC if it tripped. My question is if it was installed in the unit how would it get wet? So it must be an add on or one that you plug in at the pedestal. Your unit could be okay being it is reading 124 volts and no lights, I think I would be looking inside if I understand correctly. the common places are the head and sink area for the GFI. They will trip from moisture and stop the AC current. But Hell I have been wrong before.!!!
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-13-2013, 05:49 PM   #9
Love My Sunseeker
DXSMac's Avatar
Found a technical manual:
https://www.dyersonline.com/lightspe...tfile_id/1347/
Apparently, if the voltage is within range, but power is prevented, CALL TECHNICAL SUPPORT! Which is what I did.
But original question: Do RV's have "built in" surge protectors, which is what a mobile tech told me? I am skeptical of this!
Old 03-13-2013, 05:51 PM   #10
Love My Sunseeker
DXSMac's Avatar
Yeppers, I checked the ground fault. I only have one, in the kitchen. I had to turn on the generator to check the ground fault.
I have removed the surge protector (it was a portable one), and so far, no problem, but I'm antsy about not having one!
