Old 10-28-2012, 10:52 AM   #11
A word 'surge protector' describes many different devices. An answer is not possible without first defining the problem.
For example, polarity reversal does not cause damage. But is an indicator of poorly trained workmanship that might create other undetected problems. But reverse polarity does not cause damage. A protector typicaly does not protect from polarity reversal.
Increased or decreased voltage, not harmful to electronics, may be harmful to electric motors. Some protectors only disconnect from AC mains when voltage changes too much. Those use switches; not varistors.
Current spikes that might harm electronics are typically hundreds of thosuands of joules. Two protector varieties exist. One located near appliances would somehow absorb that energy. Another connects that energy harmlessly to earth. Must be located as close as possible to the AC power pole earth ground. Not safety ground. Earth ground. Earth is where hundreds of thousands of joules (ie lightning) are harmlessly absorbed.
Those two devices both use varistors. Difference is whether those varistors connect short (low impedance) to earth.
Spike from generators are best solved inside a generator's design. Least expensive solution is a little more expensive generator that does not create those voltage variences and spikes. Protectors are not designed to avert continuous spikes such as from a generator. Protectors are for infrequent anomalies that might otherwise be destructive.
westom is offline   Reply With Quote
Old 10-28-2012, 12:21 PM   #12
Terier's Avatar
To the OP
If by chance you are asking if you need to buy both units (30 amp & 50 amp) the answer is no. What RV do you have?
Old 10-28-2012, 05:41 PM   #13
Oklahoma Proud
MillerTime's Avatar
My surge protector from progressive was about $80 for 30amp. Shows reverse polarity, open neutral, and open ground.
And reversed polarity CAN cause problems- # 1 you can be shocked- many things ground through the metal in them that you can come in contact with. # 2 ground and neutral is not made to handle the same load as positve side and can cause a fire, besides that my surge protector wont allow power to the trailer if reversed- so I'm not camping there.
Surge guards, power protectors and voltage regulators (which are much pricier) are different than a surge protector though some have the surge protection- some you have to use both for full protection.
Old 10-28-2012, 05:52 PM   #14
Oklahoma Proud
MillerTime's Avatar
I would be very carefull of some of this advise and ask an electrician about it.
Old 10-28-2012, 08:35 PM   #15
I am going to have to say that I recommend a surge protector. I have know a few people that have had pretty major electrical issues from surges at campgrounds. One was my former service manager at my tire store. He lost a lot of the wiring to the main circuit board. Had to replace the wiring to it and the board itself. I had a surge at a campground in Lancaster and it melted the surge protector. I can only imagine what it would have fried if I didn't have one. So, my opinion, get one, worth the money. I am sending one to the dealer to have it hardwired in my 320- that is one order.
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
Old 10-28-2012, 08:36 PM   #16
hkreck's Avatar
Expense is in the eye of the beholder, $70,000+ MH is an expense that I'm willing to pay $200-300 to protect. Remember your home has a grounding rod driven into the ground at the electrical meter to protect it. So I guess you could get real cheap and drive a cooper rod and wire into the ground everytime you set up at a camp.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 10-28-2012, 08:45 PM   #17
Oklahoma Proud
MillerTime's Avatar
Yep cheap insurance for sure.
That's Also why you need to know for sure that the ground and neutral are wired properly, since we can't have ground rods we are only grounded through our cords and trusting our power post.
Old 10-28-2012, 08:59 PM   #18
dfskinner's Avatar
Progressive Industries 30 Amp Portable Surge Guard - Surge Guards - Power Protection - Electrical
this is the one I use..... and good insurance? I don't think I would ever plus into any power source without first plugging the surge guard in.... I like this particular one because it uses the integrated polarity tester to the check the status of the source prior to use.... I blew the fuse and a GFCI in my old trailer and had to replace an outlet and a fuse..... not doing that again.....
dfskinner is offline   Reply With Quote
Old 10-29-2012, 05:36 AM   #19
ret2006's Avatar
I too recommend the Progressive Industries product. I would strongly recommend the EMS (Electrical Management System) not only a surge protector but measures voltage high and low, open neutral, open ground, reverse polarity, time delay for A/C compressor. I prefer the hard wired version with the remote display so I can see what the voltage is at any time.
This summer my Progressive EMS-HW50C possibly saved me an air conditioner compressor as the temperature outside was 107 degrees F, older COE campground with less than adequate electrical power, many big rigs with two A/C's running full force, voltage would go down less than 104 volts. The Progressive unit would shut power off power to my rig until voltage went above 104. I moved to another area of the park where there were not as many campers and on a different electrical run and had no problems. Thanks to the Progressive EMS I still have a A/C compressor and some of the folks in that campground probably are having theirs repaired.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-29-2012, 06:16 AM   #20
Earth Station's Avatar
ok ........ a question We currently have a 50 amp surge protector. Next weekend we are camping with 30 amp. Do we plug the 50 amp into the RV then connect the 50/30 thingy in??? We never plug in without the surge protector. Just not sure with a park that is 30 amp!! I hope this makes sense! Thanks.........
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
