Old 05-02-2016, 06:10 PM   #1
CarpeDiem's Avatar
Unhappy Surge Protector Question
I'm thinking about getting a surge protector. I know just enough about electricity to avoid getting killed by it. I don't aspire to learn any more than I need to know. That said, the big dog in RV's seems to be Progressive Industries. On Amazon the prices range from $$$$$ down to about 80 bucks. My question is this will the inexpensive one save my new TT or should I spend the big bucks on all the bells & whistles even though I will never understand what it all means? Thanks in advance for all words of wisdom.
CarpeDiem is offline   Reply With Quote
Old 05-02-2016, 06:11 PM   #2
Fulltime family RVer
I'm be same as you- don't know enough to know better, but basically it came down to a Progressive Industries *EMS* or bust.
ependydad is online now   Reply With Quote
Old 05-02-2016, 06:30 PM   #3
clr
The basic level of surge protection is the same in both units. The differences are in the bells and whistles. If you want basic protection from most problems that you will see go with the basic unit. If you want to see exactly what is going on in real time and be able to see what is wrong from inside your unit go with the most expensive unit. The biggest difference between the two is that the less costly unit will not protect you from high/low voltage or power off frequency.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-02-2016, 07:15 PM   #4
camping baba's Avatar
No matter which model you choose I would buy from Progressive Ind . They stand behind their products .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 05-02-2016, 07:24 PM   #5
Broadway Joe's Avatar
How much do you want to spend for insurance. The progressive EMS protect all the electrical systems in your trailer. One bad campsite can cause havoc replacing air conditioner microwave tv etc. The progressive EMs also has a lifetime warranty.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 05-02-2016, 08:21 PM   #6
CarpeDiem's Avatar
Joenic53, I'm not sure what you mean. I will have plenty of insurance. But I don't want to double down on something I will never use. If I need the most expensive surge protector, that's fine. But if a lesser model will do the job and I don't have to become an engineer to use it, even better. It appears that all the Progressives have a lifetime warranty.
Old 05-03-2016, 09:18 AM   #7
How much would it cost to replace all your on board electronics - AC unit, furnace board, fridge, microwave, inverter, HWH, tv, stereo, etc? X2 on Progressive Industries EMS units. As long as your thinking of doing it you might as well do it right the first time.
Old 05-03-2016, 09:32 AM   #8
jeff64's Avatar
Yup X3
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-03-2016, 09:41 AM   #9
Number of anomalies that are called surges are more than you have fingers. No protector protects from all. Anomalies that are typically problematic in campgrounds include low voltage, high voltage, open neutral, and floating safety ground. A protector, at minimum, should protect from those anomalies by disconnecting power.
Many will discuss a long list of other anomalies including frequency variation, harmonics, missing earth ground, RFI, bad power factor, lightning, EMI/EMC, etc. Those are rarely a problem, are not detected by protectors, or are already made irrelevant by what is inside appliances.
Your concern is to avert problems now; not get insurance payments next month.
Does a protector you are considering at least do those basic minimums? Unfortunately, protector selection means first learning what various anomalies are to therefore judge which are most problematic.
westom is offline   Reply With Quote
Old 05-03-2016, 10:10 AM   #10
elrand's Avatar
ok the difference between the base model SSP and the high end model EMS is as follows
SSP is a surge protector only
Open Ground, Open Neutral & Reverse Polarity Detection
Mis-wired Pedestal Indication
Surge Failure Indicator
Thermally Protected
and the
EMS is an electrical management system
has all the features of the SSP plus
Oven/Under Voltage Protection (protects if the pedistal isnt getting the right voltage to your unit)
Accidental 240V Protection (even if you only have a 120v 30a unit and the park has an open neutral this can happen)
A/C Frequency Protection (here in the US we have 60hz and the electronics are setup to run on this if it getting the wrong frequency electronics can burn out even if your voltage is correct)
Time Delay (this to make sure power is stable before letting power go to your unit. if the EMS sees a problem or when you plug in it will watch power for 2min 16 sec{factory setting} before letting potental bad power flow)
Built-in Display
Previous Error Code
Locking Bracket (this is for the plug in unit so you can make sure its still there when you go to leave and doesnt grow legs)
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
