Old 08-31-2015, 06:44 PM   #21
TURBS's Avatar
Originally Posted by Blaster 84 View Post
I just had my Progressive cut my electricity off twice in the last hour. The read out code said it was due to low voltage. It not only saved me the cost of the repairs as a result of the damage it could have caused; but also a great inconvenience since we are about 1600 miles from home.
30 amp trailer?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-31-2015, 06:53 PM   #22
Responce to Surge Protectors
Yes i would recommend one. But secure it with a large lock(big enough to go around the wire) and chain it to your trailer.
Bluesky is offline   Reply With Quote
Old 08-31-2015, 06:59 PM   #23
TURBS's Avatar
Hardwired version requires no lock
TURBS
2011 32bhok Sabre
Old 08-31-2015, 07:36 PM   #24
On the Progressive units, when checking the low voltage, and low voltage detected, the unit cuts off the power. Do they come on automatically when power come back to normal or does one have to reset it manually? If it has to be reset, then if off all day, then could be refrigerator not come on and food lost. Also, if it does not come back on, and pets in camper, the camper could be get very hot due to loss of A/C.
It seems logical that it would come back on if voltage comes back on to normal.
I have been camping 20+ years all over, I have never had a Progressive type unit and never had a problem. Maybe I am playing Russian roulette. But it does seem like something good to have.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 08-31-2015, 07:38 PM   #25
TURBS's Avatar
Comes back on automatically when power is @ a safe level.
While in Nashville 30 amp circuit was down to 103 volts on the moniter.
I unplugged and hooked up my 50 amp dogbone to the 50 amp side and had better voltage, 112v
If your fridge is on auto it'll kick to the gas side, unless of course you have a residential fridge.
TURBS
2011 32bhok Sabre
Old 08-31-2015, 08:43 PM   #26
The OP was talking about using a surge protector because his camper was going to be hooked up full time. For those that don't know, it doesn't matter if the camper is hooked up full time or for 5 seconds. A surge protector is needed anytime the camper has power applied to it.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 09-01-2015, 05:51 AM   #27
I installed a Progressive Industries hard wired 30 amp EMS in our Sunseeker this past spring. During the following six week trip it shut off power several times.
Once when the voltage dropped too low at a full campground with everyone running air conditioners.
Several times when we went over 30 amps, usually when the lady ran her hair dryer with the water heater and heat pump going. The EMS always tripped before either the pedestal breaker or the coach main breaker, and it reset after its 2 minute time delay.
Once it gave an error code when I hooked up to a pedestal, and would not allow power to the coach. The error code indicated an open ground. I double checked with my plug-in circuit tester for 110 volt 15 amp receptacles, and it confirmed the open ground. I moved to another site and notified the park owner. Later that day he came and we found and fixed the problem at the pedestal. He was quite happy that I had found the problem before there was an incident, and that he didn't have to call an electrician to fix it.
We've had our Sunseeker for four years, used it over 400 nights, in at least 150 different campgrounds, and there's no telling how many times we've plugged into a pedestal that had a problem and we didn't know it.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 09-01-2015, 06:32 AM   #28
Fulltime in our Berkshire
KennyGolub's Avatar
Progressive industries ems hardwired! Got it as a gift and replaced the portable one. I like not having to take the few extra steps to put the portable and lock on when first arriving at the CG and in a hurry to pull out the chairs and beer
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 09-01-2015, 06:59 AM   #29
EastlakeRoo's Avatar
I agree having a surge protector is the way to go likes others have commented on. If you can get it hardwired then thats a added bonus. Don't have to worry about someone walking off with it and its one less thing to hook up as its always hooked up inside the trailer.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 09-01-2015, 07:00 AM   #30
That type protector is only needed when low voltage would be a problem for powered on motorized appliances. If motorized appliances are not on, then low voltage is not a problem. Then this type protector need not protect anything.
Because it is called a surge protector means it also protects from a completely different type of surge (ie lightning)? Only if it makes a low impedance connection to earth and its specification numbers claim to protect from that completely different anomaly.
westom is offline   Reply With Quote
