Old 05-22-2015, 06:15 PM   #31
Smile Surge Protector
We've been camping in various RV's for over 40 years. Never used a surge protector, never needed one.
RV- 2014 Thunderbolt XLR 386X12 Called "The Castle"
TV- 2013 Ram 3600 DRW Diesel Called "Hercules"
rick42wood is offline   Reply With Quote
Old 05-22-2015, 06:30 PM   #32
TURBS's Avatar
Yet
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-22-2015, 06:43 PM   #33
Left Coast
Originally Posted by TURBS View Post
Yet
TURBS
X2
Old 05-22-2015, 08:06 PM   #34
Originally Posted by bob caldwell View Post
X2
x3
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 05-23-2015, 07:25 AM   #35
f5moab's Avatar
I've always figured a surge protector is like insurance. You buy it, and hope you never need it, but if you do, you are glad you have it. And a surge protector is cheap insurance (one time pay), usually easy to install (was in my popup) and even though, 80 percent of the time I camp in areas where the only power is from my Honda (if it is working that day), I feel safe connecting to the pedestal.
f5moab is offline   Reply With Quote
Old 05-23-2015, 09:43 AM   #36
Testing electrical hookup location
Fonize, I agree with you.. First plug in a electrical analyzer first to see if the correct lights appear. I do this at each & every campsite. So far, I guess, I have been lucky, but all have checked out OK. But, one never knows. Then I plug in my surge protector. One can never take things for what they should be.
utahlucky is offline   Reply With Quote
Old 05-23-2015, 09:47 AM   #37
7 Year Class A RV'er
That's what I like about the EMS devices at Progressive Industries (sure the other folks have the same feature, too). They have a built in delay that checks the power source before allowing the power to turn on. They then monitor the line continuously during usage and, if they turn off the power for any reason, they log the error code so you can see it later. They will come back on as soon as the problem is corrected (high voltage, low voltage, etc.) but you still know the reason the microwave is blinking when you return to the coach. They also tell you how many amps you're pulling on each leg of the power.
2015 Legacy SR340 360RB
Old 05-24-2015, 09:54 AM   #38
Originally Posted by gljurczyk View Post
I disagree with that statement being electronics are more sensitive. The two most used are either TRC or Progressive. Both are great and either can be purchased for hard or portable.
As I noted earlier. most will only recite a first myth told. And not learn the underlying whys. For example, 120 volt power from this UPS in battery backup mode is 200 volt square waves with spikes up to 270 volts. This power can be harmful to motorized appliances. And is perfectly ideal for all electronics. This UPS is typically of many UPSes. And is why UPS manufacturers recommend not powering motorized appliances from their products. Electronics are some of the most robust appliances in homes and campers.
Low voltage is also perfectly fine for electronics. Again, because electronics are so robust. Same low voltage can be harmful to motorized appliance. This anomaly, too often found in some campgrounds, should be addressed by the protector. To protect motorized appliances. Electronics are not harmed by low voltages.
One anomaly that can be destructive to electronics is the high current created by an anomaly such as lightning. Protectors not attached at the pole (within feet of earth ground) do not claim to protect from this type of anomaly. But this anomaly is rare; therefore often ignored in protectors for campers.
Anyone who recommends any protector should also say why. Disingenuous is to recommend a protector only because "I use it". Best recommendations first cite which anomalies are of most concern. A problem must be defined before any solution can be recommended.
westom is offline   Reply With Quote
Old 05-31-2015, 12:28 PM   #39
BuckeyeGal
I use the 50 amp Progressive Industries pigtail. Selected based on info from wife's uncle (an electrical engineer). His observation: "when these units provide the ultimate protection to your TT, they fry. do you really want all that heat generated inside your TT?" So I went with the pigtail version.. The braided steel cable security lock takes care of sticky fingers
Terry & Carol
2012 Sabre 31-CKTS-6
2003 F-250CC 7.3L Powerstroke
buckeyegal is offline   Reply With Quote
Old 05-31-2015, 08:41 PM   #40
Nothing wrong with the pigtail setup, but the unit does not simply burst into flames when it fails. What actually happens is the small computer control board inside the unit burns out, possibly with a small plume of smoke (very small). If I was worried about something bursting into flames, I would be concerned about the inverter, which is in the same compartment.
