Old 04-27-2011, 12:13 AM   #1
Switch with solar panels
On the weekend I completed installation of two 125W solar panels on my 5th wheel. I had planned to include a switch in the cabling between the combo box on my roof and the controller, but when I went to pick it up at the local RV dealer, the guy I talked to said it can cause damage to the panels or controller to disconnect the power. This sounded strange to me, so I figured I'd just do the install and see how things go... installing the switch later if it seemed appropriate.
Having the solar running now for a few days, and only using the trailer every couple of weeks for the weekends mainly, I figure it might be best to not have the batteries charging all the time. I'd just switch it on the night before we go out so it tops up again during the next day. I'm hoping to get a few answers from the knowledgeable people here:
Thanks in advance for any help.
Howard
hdarby is offline   Reply With Quote
Old 04-28-2011, 05:48 AM   #2
Herk7769's Avatar
Howard,
I also would like to add panels and was hoping someone would answer this thread. Perhaps a dedicated solar Forum might be the place to ask.
Solar Electric Power Discussion Forum by Northern Arizona Wind & Sun - Powered by vBulletin
Please come back and post what you find out.
I also hope you took pictures or your install!
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-28-2011, 09:29 AM   #3
Happy to Be Camping
Shawomet3's Avatar
Location: We live in Rhode Island, but our hearts are in New Hampshire
I am installing panels on my rig also. I had them on my last one. I just used the charge controller. It treated the charge much the same way as when you are plugged into shore power-charge, maintain,float. I felt that since I didn't have to disconnect my on-board charger when I was plugged in for a long time, then I shouldn't have to using my charge controller.
I had 4- 6 volt batteries and they did not "bubble out" any more than before without the panels.
I hope this helps a little bit. Good luck.
Shawomet3 is offline   Reply With Quote
solar
