Old 03-16-2019, 08:23 PM   #1
Tank Monitor stopped working-NEED HELP FINDING FUSES
Need some help please. I have a 2018 Forrester model 3011. I cant find where the fuse box is for the panel monitor for the water, grey tank and black tank. LP works but the other three donít. I looked under the bed but there are no fuses listed there that say Tank Monitor. In their kitchen cupboard there is a sticker that says there is a separate panel for it, but I cant find it.
Thanks!
pranxsterr is offline   Reply With Quote
Old 03-17-2019, 07:37 AM   #2
On a 2018 you should have the one Control system. The 4 tanks (fresh, gray, black, & LP) are all sent to one module. If your LP is working power is being supplied to the tank monitor module which I believe is located under one of the drawers in the bedroom. You may have a problem with the actual sensors on the tanks (very common) or a loose common ground to the 3 tanks (unlikely). If you go to each individual tank you can jump a wire from the common (lowest sensor on the tank) to the three others, one at a time. if it is a sensor issue your panel will show a level corresponding to the sensor you have jumped to the common.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 03-17-2019, 10:09 AM   #3
Thanks for your reply Steve. I will check it out
fuse, tank
