01-09-2020, 08:52 PM
Tapping a 120V circuit from a 240V circuit
Hi. I apologize, this is not an RV related question. I know there are some very knowledgeable people here and I've long since forgotten my password(s) to the home improvement sites. I accept that this post may be deleted as being improper. Thanks if it remains.
My neighbor is having a water softener, filter, etc.... installed and ask me to help him get a new outlet installed. His well pump is in a separate little room in his basement and he said there is a switch there for the pump that would be convenient to tap off of since the new equipment would also go in this room. I have not seen his setup yet, but if it is like mine then his well most likely runs off a 240V/20A feed.
Ok, so what I what to know is if its "OK" to tap a 120V circuit off an existing 240V feed? Personally I don't see a safety problem with this. The breaker with protect the line. None of the wires can ever draw more than the 20A of the breaker. There should be no problem with the "unbalanced" load on the neutral. I doubt the well pump actually draws anywhere near the 20A of the circuit. A quick search shows that a 1HP well pump is ~9A or less than 50%.
If its not OK, why and what options are there? Running a new line is unlikely as I believe his panel is full. We could could put a small sub panel in the well room and then run a circuit to the well and the new outlet, but this seems like over kill. We could try to tap some other nearby circuit (basement lights, etc..) but I see the advantage in keeping all the water/well related circuits on one branch.
Thanks again.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
01-09-2020, 09:11 PM
Do you even have a neutral (white wire) on the pump circuit? It isn't required for 240 volts so it often isn't run with the circuit unless something is 120 volt.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
01-09-2020, 10:01 PM
If I was doing it and had a fourth wire in the existing run I would cut the 240 volt 20 amp feed to the pump and insert a small sub panel, reconnect the pump to a 20 amp breaker in the subpanel and add another breaker for the receptacle.
I'm not sure how you would add a 120 volt circuit without a neutral. You could get 120 volts between a hot leg and ground but that's not safe.
Kirk
2017 Forester 3051S
01-09-2020, 10:05 PM
Good question, I didn't think of that. When I re-wired my house I ran a neutral with all 240V circuits. I figured its already required for dryers and stoves that its only a matter of time before they all require it. Get ahead of the curve.
I asked my neighbor to check. If there is no neutral then Plan A falls apart. I'll expand the question a bit. If the breaker has the proper spaces for two wires could I run a new line from one side of the breaker?
Jim M.
01-09-2020, 10:07 PM
Originally Posted by Kirk S
If I was doing it I would cut the 240 volt 20 amp feed to the pump and insert a small sub panel, reconnect the pump to a 20 amp breaker in the subpanel and add another breaker for the receptacle.
I thought of this. Thats a lot of work, and cost for a single outlet. If everything else falls apart I'll probably suggest just taping something else.
Jim M.
01-09-2020, 10:27 PM
When I had to add a 120 volt circuit to a full panel I was able to replace one full size single pole breaker with two half size breakers in the same space. I reconnected the original circuit to one and ran the new circuit from the other.
I was fortunate that the brand panel I was working with supported that type breaker.
I have done it with GE and Cutler-Hammer.
Kirk
2017 Forester 3051S
01-09-2020, 10:37 PM
Depends on the type breaker if it’s a 20 amp breaker per leg and you put an extra wire in one leg going to the plug and have a neutral bus to put your neutral leg to ,it will work as long as you do exceed 20 amps per leg . It’s probably a code violation in most places but it will work and is safe as the breaker will trip with a fault or over load on one leg or both it’s 20 amps per leg it just trips both sides no matter which leg has the fault on it to keep a 240 volt device from only getting 120volts and damaging the device . The only difference in a 240 breaker and 2 , 120 breakers on different busses in the box is a fault on 1 leg will trip both sides of a 240 breaker to protect the device and to prevent someone from coming along to work on it thinking it’s off but really only 1/2 power. I have a plug wired into one side of a 240v 20amp breaker in my power panel on the outside of my house to plug my truck up it the winter. Only difference is the other side is vacant it went to a hot tub we no longer have and I didn’t want to buy a breaker just for one plug that gets used very little.
01-09-2020, 10:41 PM
Is the power cable to the well a four wire cable???? if it is it should have a black wire red wire a white wire and a green wire Yes it can be done if all parts are rated for 20 amps.
Black and Red wires are 220 volts 110 volts each to the common wire.
White wire is common or neutral wire for 110 volts back to the neutral bar in the breaker panel.
Bare or Green wire is the ground wire and is to be used as a safety wire back to the ground bar in the breaker panel only!!!!!!!!
If the power cable to the well is only a three wire cable the answer No.
It is very dangerous and illegal to use the ground (bare or green wire) wire in a 3 wire cable as a common or neutral wire. If you do this and some is electrocuted I smell a law suit.
Be very careful with this Tim
01-09-2020, 10:48 PM
Thanks to all for the suggestions so far. Just to clarify, I would never use the ground as a make shift neutral. I realize the danger of such. I'm hoping there is the neutral wire but I'm betting against it.
Jim M.
01-09-2020, 11:04 PM
2012 Solera
JLeising
2012 Solera "S"
Calif SF Bay Area
01-09-2020, 11:38 PM
For safety's sake you shouldn't use one leg of a bridged breaker. Install 2 single 20A breakers in it's place, and of course, you'll only use one.
Marking tape is perfectly acceptable as long as local regs allow it.
Just wrap all exposed wire with white marking tape on each end, and connect it to the neutral buss.
https://www.amazon.com/SAISN-Electri...8630952&sr=8-2 I'm assuming the existing run includes a ground wire.
01-10-2020, 12:22 AM
Coach
I would advise against tapping one leg of the 240v. I also wouldn't recommend the subpanel off pump wiring as you'd likely only be feeding it with #12 wire unless you would make a new run. The duplex breaker in the main box is probably the best idea. If you want to do the subpanel, I would recommend changing the 20a 240 in the main panel for a 50a and install a 50a subpanel with #8 wire providing his electric service can handle that.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
01-10-2020, 03:00 AM
You guys are killing me. You cannot use a 20 amp 3 wire 240 volt circuit to get 120 volts circuit. It is very possible that the existing pump might just be 120. Problem solved. Did anybody think about ordering a 240 volt water softener if need be? Some softener systems don't even use electricity.
What's the odds that this separate little room has a light in it? Softeners draw very little amperage. Mine has a wall wart transformer. Add an outlet to the lighting circuit.
01-10-2020, 02:45 PM
Don't. First off it is not code. If something would happen and there is a fire the insurance company won't pay. Do not ever count on a breaker tripping to save wires from melting and burning down your home. That's why you have smoke detectors to get you out.
01-10-2020, 02:49 PM
Once upon a time, a lot of houses had a wire running from the fused panel to the receptacles and a bare wire running from the recept to earth ground under the house to complete the circuit. Functionally this worked, but, not safely. Then "neutral" (common, white) wires were incorporated with the power wire (romex, etc.), much safer and easier, then 60 odd years later, the ground (grounding, bare wire was added). You sound like a thoughtful guy who covers the angles. I believe you can figure out what will work best for your situation
01-10-2020, 02:52 PM
Jim M.
It is not much and probably the safest way to go, you can cut off whichever whenever you need to.
Electrical services are nothing to cut corners on..........Fires result as do deaths as a result of "Jury Rigging"
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
01-10-2020, 03:35 PM
I see you have mentioned wiring to a new outlet in the basement. No matter how you get the supply, "basement" and "well room"=wet area and you should be using a GFI outlet.
01-11-2020, 08:01 PM
Stay away from touching 220 circuits when using the current on a water system. I never trust one breaker to trip a second one. Just not enough internal energy to do the job (FAST). Here are easy, safe and code approved ways. Buy a Mini Breaker set. Two circuits from one panel lug. Square D, GE, and Murry sell them. Number two and the safest method when faced with space issues as you describe is to find a circuit with little load in the house. Many circuits in homes have these installed. Add a GFIC-Arc Fault Receptacle outside the breaker box and send a new wire to the unit you're trying to power along with the original supply line. Anytime water is involved, along with electricity, you NEED protection. It's CODE. Everything down steam of the GFIC will also be protected. I have no problem with a double lug as far as safety is concerned but inspectors cannot approve them if a sale is involved. Good luck but also get proper help with your project.
01-11-2020, 08:06 PM
Originally Posted by weatherguru1
...I have no problem with a double lug as far as safety is concerned but inspectors cannot approve them if a sale is involved. Good luck but also get proper help with your project.
Are you saying that a double tapped breaker is against code. A number of breakers (like Square D QO) are designed to be double tapped and, unless it is a recent change, why put a feature in a spec sheet that is counter to the NEC.
2015 335DS
01-11-2020, 08:48 PM
Scott, In our area, Western PA, inspectors will not allow double lugs. You can use double breakers, I.E.Mini breakers, as I said. My inspector works specifically for Atlantic Inland.
The NEC is there for a reason, Safety. Why it is not he same across the land is anyone's guess. For example, and there are many, NY State allows and demands Breaker Boxes be grounded to Natural Gas Lines. Try that in PA and there goes your License and or credibility. Go Figure.
