Old 05-21-2012, 10:45 AM   #1
Thermostat not cycling
I have a Rockwood 2703SS
When we first started the furnace/air it clicked on fine but when it reached it's temp & shut down it would not come back on when the temp got colder in the camper. Took the thermostat cover off & there is a glass fuse that I replaced & worked fine for that initial turn on but would not cycle again. When I went to pull the glass fuse out I used a butterknife because that's all I had handy, when I touched the connections when pulling out the fuse the furnace/air would work
If I keep the fuse in & use some type of metal piece touching it the unit will run. It's weird & I can't figure it out
Bandit7 is offline   Reply With Quote
Old 05-21-2012, 11:15 AM   #2
Are you saying you use something metal to hold the fuse in the holder?
Old 05-21-2012, 11:21 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Either there's a short in the low voltage wires causing the fuse to blow or the fuse you have is not rated high enough for the circuit.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-21-2012, 11:25 AM   #4
It's not really holding the fuse in, it's touching the fuse & the connections at the same time. Hard to explain
Old 05-21-2012, 11:35 AM   #5
Maybe a picture would help.
Old 05-21-2012, 11:39 AM   #6
Thumbs up
It is at a campground right now but will try to get a pix this weekend
Thx
