05-27-2019, 06:53 PM
Thermostat replacement
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: ‘18 - 27, ‘19 - 27, ‘20 - 30, ‘21 - 49
05-27-2019, 07:17 PM
That's the thermostat in your Wildcat?
05-27-2019, 07:34 PM
Retired Old Fart
Just go to Home Depot, Lowes, or Amazon and get an inexpensive residential wall thermostat. That one is ancient and the newer ones are digital (still $20 or less). You can still find the old analog ones, but I would upgrade to digital. Look for a "manual digital thermostat". Or you could use a programmable one if you wanted that feature.
You want to install it as a "2 wire heat only" thermostat. Basically you will just use the heat side of the thermostat and the "cool" setting will do nothing unless you decide to also wire in your AC unit (may or may not be easy). The actual wiring will be dependent on the thermostat you buy, but for most of them it will be the RH & W terminals on the thermostat that you will connect those 2 wires to (read the paperwork with the thermostat).
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
05-27-2019, 08:10 PM
Lol. Not in the Wildcat. It's in the Peterson.
FROG IL-0076-090
05-27-2019, 08:17 PM
The lamp cord wire is what bothers me - no colors to match up to.
FROG IL-0076-090
05-27-2019, 08:38 PM
That's just a simple 'make or break' circuit on a analog Tstat. Easily replaceable with a new one from any good hardware store.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
05-27-2019, 08:50 PM
Indeed. Just figured that out looking at my own pics - SPST.
FROG IL-0076-090
05-27-2019, 11:29 PM
Retired Old Fart
Yep, colors will not matter. You just need to connect one wire to the W and the other to the Rh on the new thermostat.
