Old 12-22-2012, 07:57 AM   #11
RPAspey's Avatar
No it wouldn't need to be the same size. Just a "12"volt panel. You can't mix different nominally rated panels, ie 12v or 24v.
And yes that pwm controller would have to be replaced.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 12-22-2012, 09:25 AM   #12
Bennington Camper's Avatar
Once you bought a second PV module, you should re-wire them in series and use an MPPT controller to obtain maximum performance increase.
Glenn
NABCEP Certified PV Installer
Glenn - KA2DTH
2007 Chevy Express 1500 AWD
2005 Surveyor SV-230
Bennington Camper is offline   Reply With Quote
Old 12-22-2012, 10:59 AM   #13
RPAspey's Avatar
series is best for A stationary installation in which both panels are exposed to the same amount of light, as on a home.
But a camper may have one panel full Sun, the other part/full shade. If wired in series, the shaded panel would pull down the output from the full Sun panel. In parallel connected panels the shaded panel does not hinder the power of the other panel.
solar
