07-07-2018, 03:34 PM
...Thinking fuse, but want some experienced feedback.
07-07-2018, 05:01 PM
It's possibly fuses. Have you looked to see if there's more than one fuse for the lights?
Gotta go campin!
07-07-2018, 05:10 PM
Certified Curmudgeon
Yes, fuse is likely. That is provided that your overhead lights (sailor talk for ceiling) are 12v.
Mike Dropped
07-07-2018, 05:23 PM
Check your ground fault outlets especially the bathroom outlet. Make sure none are tripped. Sometimes a lot of other stuff is connected to these outlets.
07-07-2018, 08:43 PM
...All good advice. I'll check it out in the morning and see what fuses I can find.
07-08-2018, 01:10 PM
I don't think so.
I don't think so. All the lights are 12 volts. The Ground Fault is for 120 volt outlets.
Larry
07-08-2018, 04:17 PM
Check wiring
May want to check the wiring going to you lights, I had one with a bad crimp and it affected all the lights down stream from that one fixture. The GFCI is only for 110 vac circuit, your lights are 12 vdc.
07-15-2018, 02:05 PM
So, I finally had time to get into it. fuses were good, GFCI was tripped and wouldn't reset. Checked and do have hot wire going into GFCI. Used a plug tester and it indicated I have a hot open wire. Suggestions for tracking that down?
07-15-2018, 02:13 PM
I think your use of the word “fixtures” is causing extreme confusion. Also try substituting 120v for AC and use A/C for Air Conditioning. Communication is key.
Edit: BTW, if you are now talking about a 120v system, there are no fuses, only circuit breakers.
Edit2: Thats Open Hot and it means that your outlet has no power input. So the new suggestion is to reset the circuit breakers even if they look like they are on. A GFCI will not reset with no power.
Mike Dropped
07-15-2018, 03:24 PM
Go to your breaker and fuse panels. Check each breaker by first turning each off then back on and make sure they feel right and click right when you turn them back on. Pull each fuse and look to see if any are burnt out. If so replace them with an new one. Now go and check all the GFCI outlets by pushing the trip button then reset each one.
Do you still have a problem. Use the plug tester again now what does it say?
If you still have an "Open Hot" then you will have to check your wiring. A tough job depending on your trailer. Do you have a mousse or rat problem? One may have chewed a wire into.
Good luck!!!!
07-15-2018, 04:45 PM
Found a good Youtube video :
07-20-2018, 12:53 PM
They are unrelated issues as most have suggested. I changed the GFCI test outlet and the outlets that are GFCI are working. I found it interesting that not all outlets are GFCI. My Fridge and the other outlets (the one under the medicine cabinet, above the sink, and the 2 in the kitchen have the GFCI sticker) are on a separate circuit from the GFCI controlled outlet. I'll look for a loose wire with the lights next. There are 3 fuses marked "Lite" on the electric panel. I'm going to pull fixtures first, on the group of lights that are not working to look for a loose wire. Has anyone used a tone generator to trace a wire break like this?
07-20-2018, 01:19 PM
GFCI rules
Outlets must have GFCI protection if they are outdoors or within 6 (?) feet of a plumbing fixture. The others don't have to have GFCI protection.
Larry
