Old 06-13-2015, 03:01 PM   #11
if it only did it one time and does not do it any more it is most likly static.
gunn1976 is offline   Reply With Quote
Old 06-13-2015, 03:10 PM   #12
Originally Posted by Ford Idaho View Post
No.
This is the regulator, open the valve all the way.
No? No to what?
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 06-13-2015, 03:15 PM   #13
Ford Idaho's Avatar
Originally Posted by howie70 View Post
No? No to what?
The knob on top of the tank, it is not the problem.
Old 06-13-2015, 03:18 PM   #14
B47
Originally Posted by bubbles View Post
Same scenario at the Air Force Academy Famcamp a few years ago. Every time the ground was wet every camper (me included) got a buzz when outside and touched their rv's exterior. My power pen verified there was AC volts when I touched it to my steps. Electricians verified there was an issue and chased the problem for 4 days throughout the campground (lots of holes dug) and ended up running all new wiring throughout the campground. Took several weeks.
We camped there 3 years ago and work on the cg's electrical system was underway then. We and our friends we were the guests of didn't have any problems then.
Old 06-13-2015, 03:23 PM   #15
Flybob's Avatar
rest of the frame probably painted or powder coated (plastic) so there is some insulation, Handle on propane tank neither.
Got a test meter? Measure voltage between tank valve and Ground ( not trailer gnd)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-13-2015, 03:59 PM   #16
Crockett's Avatar
Eclipse Tools 400-029 Receptacle Tester - Standard Outlets
trouble with links on this ipad and interface with my brain. flybob has a point. usually when you get the pulsation in the reg you hear it as well, almost resonates through the tanks. composite walled trailers will limit " hot skin" transmission to just a few locations. as far as a noisy reg being an issue, im not sure if its a problem. heard it once in a great while, usually when first pressurizing. id have a polarity tester and 30/15 adapter to test every source I plugged into just for GP.
Crockett is offline   Reply With Quote
Old 06-13-2015, 04:02 PM   #17
Thanks Lou for posting the video. You may have saved someone's life! I've been in the electronics business all my life and I can't begin to tell you how many times I found (usually the hard way) a floating ground! Using that voltage sensor sounds like a great idea.
Stan
swuebbels is offline   Reply With Quote
Old 06-13-2015, 04:08 PM   #18
Ford Idaho's Avatar
Oh, I have one......
Thought it was something I did not, I like DIY toys..
Old 06-13-2015, 08:29 PM   #19
Wet ground/feet, aluminum siding and reversed wiring/poor or no ground is a disaster waiting to happen. Saw a next door camper plug in and then go to attach the water hose, he was lucky - 115 VAC to ground from the aluminum siding. He unplugged quickly before the kids had a chance to touch the trailer. Inverter was just replaced, typical quick service. It's easy to check the post/tt with a gismo for missing legs, grounds and reversals.
I carry a 30 to 20 amp plug to check the post.
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 06-13-2015, 10:01 PM   #20
I knew that. I was just saying that is the only place he felt it. You mentioned the regulator, is that an indication of a bad regulator?
2016 Flagstaff 23LB
propane, tank
