Old 06-08-2015, 07:21 PM   #11
DanM-AZ's Avatar
How did you verify that the output of the AC transformer/input to the USB gang box is 12V? I saw nothing in the description that told me that.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 06-09-2015, 11:31 AM   #12
Just a hunch, and I figured I'd use it in the house otherwise. It is 12V / 6500mA Output. Looks pretty good - smaller than I expected.
alfista is offline   Reply With Quote
Old 06-09-2015, 12:52 PM   #13
Kzutter's Avatar
Question Tie directly to 12V ?
Originally Posted by alfista View Post
I ended up buying this: which has 8 ports and runs off 12v.
Hi alfista, Can you confirm that the Aukey can be tied directly to 12v and not use the included power supply?
Thanks,
Ken
2015 EVO T2460
Carson City, NV
Kzutter is offline   Reply With Quote
Old 06-16-2015, 09:36 AM   #14
The power adapter has a four pin connector, but only two wires run from the transformer. I cut it and wired it to the 12v panel and it is working. iPhones work mostly OK - they complain once fully charged. It does not seem to be as fast as an iPad charger but I haven't compared directly. Also, haven't tried charging a full-size iPad.
