tired of fighting voltage drop, distribution panel install
Have had to many problems running inverter off the factory wiring. It would cut off due to low voltage.
So I oversized and ran 4 gauge about 20 feet to the inverter and moved factory wiring to the block. Ran 1 gauge from battery to fuse then to distribution block.
Now I have room to expand and the voltage drop pulling 30 amps is low.
whats left to do is add some tubing over the exposed wires and some tie downs.
2015 silverback 31IK
2023 f350
