Old 02-21-2016, 06:38 PM   #1
Tow cable replaced and lost 12v power
Newbie here. Picked up our 26dbh and while turning into our driveway the cable got stuck on something and tore. I just installed a replacement and all of the lights, turn signals work but I don't seem to be getting any 12v power. As I said I am new to this so I apologize if this is a dumb question, but even if the battery is just about dead shouldn't the act of plugging the 7 pin into my car provide me with power to interior lights, power tongue jack, etc?
Tngahan is offline   Reply With Quote
Old 02-21-2016, 06:45 PM   #2
Ford Idaho's Avatar
Between the battery and your unit there should be one of these.
If so press the little black button.
Old 02-21-2016, 07:00 PM   #3
I found that and pressed the button and nothing changed.
Old 02-21-2016, 07:20 PM   #4
Ford Idaho's Avatar
Did you check the fuse under the hood yet?
Does the plug in have power?
Old 02-21-2016, 07:21 PM   #5
Is this what you are referring to? There are 2 right next to each other and the black wire comes out of the box with the pin wiring and into the one on the right.
Old 02-21-2016, 07:36 PM   #6
caper's Avatar
Check your fuses on the main electrical panel. The short could have blown the fuse. They will the the high amp fuses most likely 40 amp.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
caper is online now   Reply With Quote
Old 02-21-2016, 07:47 PM   #7
dannyabear's Avatar
Do you have 12 volts at the jack on your truck? I think Chevys are hot all the time and Ford and Dodge are on/off with key.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 02-21-2016, 08:13 PM   #8
The Chevy's/GMC I've owned you had to install the 40 amp fuse in the EPC under the hood. GM puts a dummy plug in the slot for the 12vdc to trailer. Two of the trucks I had to connect a wire to the EPC stud that was taped to the existing wire harness....
mfMcFroggierPod is offline   Reply With Quote
Old 02-21-2016, 08:17 PM   #9
Carknocker Family
Ida Ratherbe Camping's Avatar
Check the fuses on your tow vehicle.
Ida Ratherbe Camping is offline   Reply With Quote
Old 02-22-2016, 05:38 PM   #10
What does EPC mean? Also, where is the slot with the dummy plug?
spudston is offline   Reply With Quote
power
