Old 11-10-2015, 12:39 PM   #1
Tow Cable replaced no more 12V to RV from TV
Hello,
I replaced the cable that connects the RV to the TV.
Everything works but the charge to the RV Battery.
I get 12V from the TV plug.
I get 12V to the junction box of the RV
I think i connected the TV hot to the the RV hot in the junction box.
The only problem.... Can't power the RV. Can't charge the RV battery either; brand new BTW.
Does anyone knows if there is a fuse that i can check somewhere in the RV?
Does anyone knows if i can check the Hot in the junction box if i charge the battery?
Thank you for your time.
Chevy Silverado 2500HD Duramax
Wildcat by Forest River
2 Kids and a Wife
andrea66 is offline   Reply With Quote
Old 11-11-2015, 12:14 AM   #2
RV = general terms
Is this a trailer/5th wheel/motorhome?
You said you have power to the 7 pin plug, to the jbox.
Just keep following the wire with a test meter and check +12v & -grds
Maybe you will find a circuit breaker, switch or loose connections.
mfMcFroggierPod is offline   Reply With Quote
Old 11-11-2015, 07:11 AM   #3
Head Rambler
There is usually a fuse or short circuit device near the battery. It may be blown. Ours is hidden behind the battery compartment. If it's a TT, they're usually underneath the tongue or just under the front cap.
Gotta go campin!
Old 11-11-2015, 04:14 PM   #4
5th wheel.
I have power to the jbox from tv.
I do not have power to jbox when I check the hot and ground coming from rv battery
2 Kids and a Wife
Old 11-11-2015, 04:15 PM   #5
I'm looking for that fuse can't find it anywhere
2 Kids and a Wife
Old 11-11-2015, 04:18 PM   #6
Can't see any fuses
2 Kids and a Wife
Old 11-11-2015, 04:23 PM   #7
fonzie's Avatar
Follow positive lead back towards battery and you should find in-line mini-breakers that can be re-set by pressing small black button....
Fonzie
Old 11-11-2015, 04:25 PM   #8
Ford Idaho's Avatar
Look for one like this between the battery box and the trailer wall.
Press the little black reset button.
Old 11-11-2015, 04:29 PM   #9
Head Rambler
In your picture there is a small rectangular device with two posts in it and the black wire looped to it. That is an auto-reset circuit breaker. It should have continuity through it. They're bad about not self-resetting and need to be replaced if they're showing an open circuit between the posts.
It also looks like the other devices are manually resettable breakers.
Gotta go campin!
Old 11-12-2015, 06:10 AM   #10
Well Looks like the little black button on that connector may have been the coulprit.
Last night I was play with it, i replaced the self resetting one and while there i decided to touch that little black button. It clicked.
Now i'm discharging the battery to test if there is anything else that may interrupt the power from my tv to the rv; i really think that was it though, couldnt get any power from the hot wire at that side and after resetting it i did.
Will keep you posted.
Meanwhile Thank You All
2 Kids and a Wife
