Old 03-28-2011, 10:56 PM   #1
Tow Vehicle battery drain
Recently the "check engine" light on my 2010 Dodge Ram diesel came on while towing my FW. I didn't think much of it until I left the trailer electrical cable connected for a few days after a trip and found the truck batteries totally run down. I now know I should not do this but my Dodge dealer checked the "computer" and it said the battery voltage was low and that was what originally turned on the diagnostic light. Since this was before the battery drain problem was experienced I am wondering if there is a problem in the trailer electrical system that was pulling down the truck battery voltage. I have a 2010 Sabre FW. I have a disconnect on my trailer battery that leaves only the battery monitor on (less than 100 mA) when open and this was open when the couple of days sitting drained my truck batteries. Any thoughts?
poodlepeople is offline   Reply With Quote
Old 03-28-2011, 11:35 PM   #2
Never looked at the Dodge wiring for a trailer connector. Ford, I know, and Chevy, I think, have a relay, that only connects the truck and the tow vehicle while truck switch is in the "on" position. If Dodge has a relay, yours may be bad, as in shorted and always connected. You also might want to make sure you have everything turned off in the camper, lights, antenna booster, water pump, etc.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 03-29-2011, 05:57 AM   #3
sherdep's Avatar
On my 2004 Dodge Ram 1500 - the 7 wire plug is always hot for trailer accessories
- you can check your's with a meter to verify since your's is a 2010 - they may have made some changes that I am unaware of since you are on the canbus and I am not.
Could be that the charger is going bad - it is electrical and anything is possible
Or you got a bad batch of Junky chrysler batteries even though I had my original battery up to about a month ago - I have heard of people getting bad batteries from the factory - unless things have changed
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-29-2011, 11:07 AM   #4
More things to check
Thanks all. I had the truck with the dealer and they said the batteries were "fine." I need to see how and when things are connected to the trailer. I have a battery disconnect switch for the trailer but I am assuming all trailer stuff is still connected to the power from the tow vehicle even if the trailer battery is not. That would explain the drain if power remains in the connection. Now, where is my volt meter?
battery
