Originally Posted by cadman99
You can't find wiring diagrams or diagnostic help because there aren't any.
Also check battery voltage when unplugged and plugged in. Voltage at the battery should go up (about 13.5VDC) if the battery charger is working.
What is current battery voltage.
X-2 - Battery "has power" is non-specific. Voltage across the battery terminals MUST be 13.5 volts or more when plugged in for the battery to be "connected" to the converter's distribution panel.
There is a current limiter covered with a red cover BEHIND the battery box that protects the battery from shorts.
You reset it by pressing a button on one of the short sides.
