Old 09-20-2015, 10:59 AM   #1
trailer plug charging
If I am not mistaken when your trailer is hooked up to your tv you are charging your battery thru the converter, right? Why not make up a cable using just the 12+ and ground, then hook those wires directly to the trailer battery? This would bypass the converter for charging but it would still work for lights, fridge and such.
You might want to install a disconnect on the lead that supplies power to the battery from the converter or pull that fuse. This would eliminate the converter charging but still allow everything else to work.
Again, this is just a thought brought on by another thread. You would want to use the heaviest wire possible to the plug. If possible I would pull all the plug pins except the 12+ and ground.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 09-20-2015, 11:09 AM   #2
Kenny kustom's Avatar
Even better...
Run a pair of 4ga from the truck battery, directly to the rv battery.
I do that, when installing a second battery and winch on car haulers.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-20-2015, 11:17 AM   #3
Witch Doctor's Avatar
Jim
I might be wrong but you shouldn't be going through your convertor, the convertor will not come into play without 110V. Your not going to get much more then a trickle charge from the TV. You can get 14 volts on a volt meter but the wire is not big enough to give you any real charging valve in amperage.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-20-2015, 11:30 AM   #4
DDC
DDC's Avatar
It does not go through the converter, there is a power wire at the plug and it charges through it.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 09-20-2015, 12:15 PM   #5
I have got to be missing something. You are right, 110V required for the converter to be running and charging, I know that. But the fuses still protect everything when the 110V is disconnected. So the power from your tv has got to be supplying power thru the converter. I don't recall any small wire hooked up directly to the battery but there could be a splice I am not seeing. The fuse panel on the converter has got to be getting its feed from the trailers battery.
Again you are right, a small wire will limit the amperage so will limit the charge. This is why I said to use a large wire from 7 pin plug. Is the 12+ feed to the 7 pin plug on the tv fused? I would think so. That would control how much charge can be supplied to the trailer battery.
So now the question is, How does the battery get charged from the 12+ pin on the tv.
This is requiring too much thinking, I getting a headache!!
Jim
George Bernard Shaw
Old 09-20-2015, 12:25 PM   #6
Yes there is, the 12+ pin I am talking about. We are aware of that. The question now is, where does that wire connect at? And what size fuse is used on the tv to feed that pin on the plug? That fuse, and the wire size, would limit the amount of charge to the battery.
Jim
George Bernard Shaw
Old 09-21-2015, 05:53 AM   #7
Jim
I'm using a WFCO converter and board. Your battery connects directly to the board. saying that the converter also connects directly to the board. You would have a fuse in the TV, Where is depending on your TV. Look at the diagram below it shows the 12 volt section directly to the board not through the convertor. So you TV is really only putting a charge to your batteries.
Name:	wire convertor 12V.jpg
Old 09-22-2015, 12:49 PM   #8
Thank you. Now I ve a big head-ache!
Lets see, the 110VAC supplies power to the converter which supplies 13.75VDC to the battery. There is a 30 amp fuse on the wire from my converter to my batteries about a foot away from the batteries. This tells me that only 30 amps is used for a maximum charge even though my converter can put out 55 DC amps. The same DC voltage goes thru the fuses and circuits such as lighting. The converter/charger and the battery or battery bank is connected in parallel with the rest of the 12 volt distribution system.
For those that don't know, In "parallel" means where the charging source (converter/charger) positive and negative output is electrically connected to both the battery bank positive and negative, and the 12-volt distribution system positive and negative, at the same time. The voltage output of the converter "smart charger" is based on a "detected" battery voltage.
When the 110VAC is disconnected the converter takes the 12 VDC from the battery and distributes it to the same circuits. The batteries measure 12.70 - 12.74 and dropping very slowly because of the load still attached.
Now put the TV into the equation. Measured at the battery, with the trailer plugged into the TV, I am measuring 13.94 to 14.01 VDC. tells me that my TV my truck) is charging the trailer batteries but probably not as fast as my converter does.
At the truck battery I measure about 14.7VDC from the alternator. That is a .7 volt lose? Because wire size maybe?
The converter I have in my 5er is a Parallax 7155 30 converter, see link below.
http://www.parallaxpower.com/7155-power-center-7155
Ok, what's all his mean? I am going to get a quicker charge from my converter than I would from my TV. In order to get a faster charge I would need to use a battery charger larger than 30 amps. This battery charger could be run off of a generators 110 VAC.
I still don't know where that splice or connection is on my trailer. From what I have learned though it doesn't matter. It is not worth getting out the signal tracer to find it.
Jim
George Bernard Shaw
Old 09-22-2015, 01:00 PM   #9
clr
OK the TV directly charges the battery of the RV when the TV is running. On my F350 the charge lead is feed from a 30 amp fuse through a relay that breaks the connection when the TV is shut off. The wire from the TV fuse and relay is 12 gauge. The charge lead connects to your 7 pin connector and therefore to your RV. The TV will only charge the RV battery and the converter has nothing to do with this.
clr is offline   Reply With Quote
Old 09-22-2015, 01:05 PM   #10
Jim
Okay, what I just read you have a 55 amp DC charger that runs off a 30 amp a/c circuit. I think your confusing the A/C amp side with the D/C side.
charging, trailer
