07-29-2017, 05:20 PM
Trailer plug too short
What would be the best way to make my trailer plug longer? The cord just barely reaches the plug on my truck, and I'm afraid it will pull out on a really tight turn. Is there an extension cord somewhere I can buy or should I just buy a foot of wire and splice it in to make it longer? It is a standard 7 pin trailer plug.
07-29-2017, 05:27 PM
Its easier just replacing the whole harness, the come in 4, 6, 8 foot lengths which you can find at Etrailer.com or on amazon. It connects to a junction box just under the front of the trailer.
https://www.amazon.com/Conntek-Black...=trailer+7+pin
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
07-29-2017, 05:29 PM
Lots of them
https://www.rvupgradestore.com/20046...9AC49E3E6357B3
Etrailer has them as well.
Long term I would get a longer harness and replace the existing one unless you are hooking up a 5er. They usually terminate in a junction box just inside or under the A frame. This would be cheaper and better and should only take 20min to replace wire for wire.
Best of luck.
07-29-2017, 05:43 PM
Originally Posted by Broadway Joe
I guess I didn't realize it was that easy. I like this idea. I'll go measure what I have and just get the next size up. I assumed it would have run all the way to the back of my trailer where my breaker panel is.
07-29-2017, 05:57 PM
Most likely not. There should be a junction box underneath it hooks to.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
07-30-2017, 02:00 PM
Hopkins 7 pin outlet
We just installed a 7 pin outlet in the bed of the truck using the Hopkins kit. Very easy install, hardest part was drilling 2 1/8" hole.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Prime Time Manf. Crusader 270RET 2012
Ford F150 5.4L B&W Companion Hitch
updated to Andersen Aluminum Ultimate Hitch 2017
07-30-2017, 02:09 PM
Can't find a wire stretcher?
07-30-2017, 03:57 PM
It is in the hardware department, right next to the bucket of steam to operate your steam cleaner
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-30-2017, 06:44 PM
If you replace make photos before disconnecting wires. Color code on new cord may, or may not match. Test the wires carefully.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
07-30-2017, 08:46 PM
Just as confused as you
Wire Stretcher sure come useful on the farm. I've used them before.
https://www.tractorsupply.com/tsc/pr...wire-stretcher
Richard & Jill
Camping since 1989, seasonal since 2000
Car Shredder Operator/Technician, Scrap Metal Recycling - retired
