Old 11-11-2015, 12:31 PM   #1
'11 390BH
Transfer switch alternative?
The transfer switch in my 2011 Berkshire gave up the ghost, and had it not been in a metal enclosure probably would have reduced the coach to ashes, judging by the scorching on the covers backside, the copper conductors were melted even.
FR tells me this is the same one they still use, has anyone else made a change to another brand?
Every neighborhood has one...in mine, I'm him!
kohersh is offline   Reply With Quote
Old 11-11-2015, 01:26 PM   #2
Head Rambler
Without seeing the unit it's hard to be 100% sure, but the problem was most likely caused by loose connections and not the ATS design or build.
There are many ATS' on the market, so you can no doubt find one that you feel comfortable with.
Gotta go campin!
Old 11-11-2015, 02:23 PM   #3
B and B's Avatar
Disclaimer on the front "Non emergency applications" says it all. Don't trust it.
There are many residential transfer switches you could replace it with. Onan for example. https://powersuite.cummins.com/PS5/P...AS-5810-EN.pdf
We used some like this in broadcast Live Eye trucks. The best solution is switches. Manual will work for ever and most installations I have been involved with are just that. One switch to move between shore power and generator
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-11-2015, 03:28 PM   #4
pashooter's Avatar
I just installed one of these in my Pursuit:
http://www.amazon.com/Esco-LPT50BRD-.../dp/B008VF91ME
Seems to be well made, uses DC relays so it should be pretty quiet (no buzzing), and I checked to make sure all the connections were torqued tightly (both mine and the ones made at the factory).
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2018: 6
pashooter is offline   Reply With Quote
transfer switch
