Old 09-27-2015, 12:57 PM   #11
Flybob's Avatar
X3 on battery tender Will not over charge.
http://www.amazon.com/Battery-Tender...battery+tender
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-27-2015, 01:30 PM   #12
A good maintainer should hold the battery at 12.7-13 volts. Much over 13.5 will lose electrolyte and affect battery life.
Harkerr is offline   Reply With Quote
Old 09-27-2015, 01:59 PM   #13
Canadiancrew's Avatar
Originally Posted by Happy Vibe View Post
If you are using a maintainer / charger I would not put it on a timer. I know the one I have will go through a charge cycle when you first hook it up then it will go into a maintenance mode. If it is a good quality maintainer it should not boil your batteries.
Agreed if you are using a maintainer then do not use a timer.
I use a multiple output maintainer in the boat. It's mounted inside the boat and keep the batteries charger all winter long. I just plug in the boat and don't have to think about it all winter long. My batteries are lasting longer than ever and I don't have to pull then from the boat as part of my winterizing program.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 09-27-2015, 02:17 PM   #14
Hoglou's Avatar
I guess this makes x4 for battery tender.
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-27-2015, 02:44 PM   #15
x5 I have 2 6v batteries and 2 battery tenders
the ones I use are from Canadian tire (NOCO Genius G1100 Smart Battery Charger)
smancuso is offline   Reply With Quote
Old 09-27-2015, 03:16 PM   #16
Jim Schings's Avatar
Originally Posted by SilverArrowPro View Post
Also, never set a battery on concrete, it will still discharge with the maintainer. keep it on a block of wood or a shelf.
Urban legend...
Jim Schings is offline   Reply With Quote
Old 09-27-2015, 03:19 PM   #17
IMO Best of all of them. We put them on anywhere from 4 to 8 race cars and a couple ATV's and Golf Carts (pit vehicles) all winter long. Never came back to a bad battery.... They make a unit that charges 4 batteries at a time. We use those and a couple of the Battery Tender Jr.s
Old 09-27-2015, 03:22 PM   #18
gasman94's Avatar
Four six volt and two twelve volt here. Battery tenders are cheap insurance against expensive replacement.
gasman94 is offline   Reply With Quote
Old 09-27-2015, 03:24 PM   #19
WFD
This used to be the case many many many years ago. Today's batteries being incased in a type of plastic has resolved this issue....as someone else mentioned...Urban Legend!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-27-2015, 03:46 PM   #20
I use a Battery Tendr, same type that I use to keep my motorcycle and golf cart batteries charged over the winter. BTW my motorcycle battery is going on 10 years old and I think this year I'm going to change it because I know it's gone above and beyond its rated life.
2015 Puma 31BHSS, 2005 Chevy Silverado2500HD
Puma31BHSS is offline   Reply With Quote
charging, winter
