Old 09-25-2015, 08:00 PM   #1
Dutchmen's Avatar
Trickle charging during winter 12 v
I'm storing my new Rockwood 2514g pop up camper outdoors this year. It will be winterized and covered well, but I am taking home my battery and store it in the garage. I want to hook up a trickle charger. I saw a Black and Decker BM3B, 12 v charger / Maintainer. It basically performs trickle charge technology throughout the winter season..... Without you doing any thinking on maintenance for the battery during the off season. Since this is my first go round does this sound like the right choice? Thanks
Dutchmen
Dutchmen is offline   Reply With Quote
Old 09-25-2015, 08:07 PM   #2
Bluepill's Avatar
Looks fine. One safety suggestion: Keep the maintainer 2 or more feet from the battery and anything flammable. I had a buddy have 2 maintainers fail and burn from voltage spikes in his utility power. Almost burned down his garage with cars and motorcycles in it.
2008 Itasca Meridian 37H
Old 09-26-2015, 12:17 PM   #3
waiter21's Avatar
Buy one of these. set it for 1 hour in any 24 hour period. plug your trickle charger into it.
You wont boil the battery and it will keep it topped off.
Canarm KHG303 24-Hour Plug-In Timer Switch Electric with One Outlet - GreyDock.com
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 09-26-2015, 10:39 PM   #4
Dutchmen's Avatar
2 good suggestions. I'll take the good advice. Thank you both😀
Dutchmen
Old 09-26-2015, 11:20 PM   #5
DaveSchwartz's Avatar
I used to remove my 2 Interstate marine/RV deep cycle batteries and leave them in parallel on an automatic trickle charger all winter in the garage. Never used any water and the batteries were still in excellent shape after 9 years.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-27-2015, 02:56 AM   #6
RV Battery Maintainer | Motorhome Battery Charger | BatteryMINDers
Trevor43 is offline   Reply With Quote
Old 09-27-2015, 11:34 AM   #7
Also, never set a battery on concrete, it will still discharge with the maintainer. keep it on a block of wood or a shelf.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 09-27-2015, 11:57 AM   #8
gasman94's Avatar
I use battery tenders (brand name) year round. They are intelligent chargers so you won't overcharge and burn off electrolyte solution.
gasman94 is offline   Reply With Quote
Old 09-27-2015, 12:16 PM   #9
bend302's Avatar
X2
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-27-2015, 12:23 PM   #10
If you are using a maintainer / charger I would not put it on a timer. I know the one I have will go through a charge cycle when you first hook it up then it will go into a maintenance mode. If it is a good quality maintainer it should not boil your batteries.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
charging, winter
