Old 01-18-2012, 07:39 PM   #1
Tripped breaker
For starters... I am very new to RV living (I have yet to complete one night in an RV.. But that is another 15 minute story..)
Purchased a used 2005 Salem 28BGSS TT (great deal!) and moved it to the park where it will stay. Before moving everything worked fine. After moving I noticed none of the lights would turn on (or were very dim). After checking the converter box I noticed a breaker was tripped. 15 amp breaker controlling "conv/WH" was the one tripped. AC was off and nothing was plugged in. Long story boring the breaker continued to trip about 45 seconds after resetting it. I switched the WH to LP and it continued to trip.
Any thoughts or suggestions? Will more than likely have to pay for someone to come out but was hoping for a general idea so that I don't get completely taken advantage of if said repair person wants to replace my "sky hook" or "board stretcher"!!
Thanks for the help. This forum has been so much help!
bts001 is offline   Reply With Quote
Old 01-18-2012, 07:47 PM   #2
papap's Avatar
If the element in heater went bad it maybe tripping the breaker.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 01-18-2012, 10:28 PM   #3
When you switched the water heater to LP, did you go outside, open the water heater door, and turn the electric off? Little rocker switch, bottom left corner. If not, the electric could still be the problem The switch inside for the water heater, only controls the propane part of the heater.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-18-2012, 10:57 PM   #4
I did not. I'll look for the switch tomorrow. Hoping it is only a burned element and I think it very well could be. New RV park and water wasn't running so element could have been dry. Thanks for the tip. I'll check it out.
Old 01-19-2012, 08:52 AM   #5
That is probably it. Let us know.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-19-2012, 08:46 PM   #6
Thanks guys -- y'all were correct. I was so glad it was just the element and nothing more serious. Luckily a guy who works at the dealer/service place also works on the side (very busy down here in South Texas with the oil and gas business and hundreds of campers -- so the service place is more than happy to let him work on the side) and with one quick visit he had things back to normal.
The outside on an off switch is very hard to find especially in low light.
Can't wait to move in and figure everything out! Thanks again for the help. I was able to determine that was the problem and he was about to fix it up!
breaker
