Old 06-26-2012, 03:11 PM   #1
Unhappy Trouble shooting
Hello everyone... I am new to the forum. I have a 2006 Sandpiper T34SP. We love it. Went to the lake last weekend and plugged into campground electricity. I went to turn the AC on and the whole main control board popped three relays...Can someone help in what could have done this? I would like to check as many things as possible before I re-connect the new one and this happens again. They are $300 a pop.
lacrista681 is offline   Reply With Quote
Old 06-26-2012, 03:13 PM   #2
High park power? At least that would be my guess.
Old 06-26-2012, 03:17 PM   #3
B47
Did you have a surge protector installed when this happened? If so, what did it tell you? If not, then perhaps there is something wrong wth the CG power supply as suggested.
Old 06-26-2012, 03:46 PM   #4
No I did not have a surge protector. I will have my husband to check the amp out of the campground plug in.
Old 06-26-2012, 04:14 PM   #5
Herk7769's Avatar
Originally Posted by lacrista681 View Post
the whole main control board popped three relays... They are $300 a pop.
Don't know much about toy haulers, so this is new to me.
Initially, I thought you meant circuit breakers, but they don't cost 300.00 each (the entire power center can be replaced for under 200. (8900 Series Electronic RV Converter Center, 65 Amps - $184.95)
So, someone help me. What went wrong; where are the 3 relays; and why did it cost 900 dollars to repair/replace them?
If everything was OK until you turned on the air, you might have overloaded the campground's supply (if it was only 20 amps), or if there was a problem with the air, you should have blown two circuit breakers at most (main and air conditioner) and they don't get replaced; just reset.
If you have a 50 amp service camper plugged into a 50 amp supply and there was an open neutral (such that your camper was supplied with 220 VAC across the power center instead of 2 110 circuits, way more than the power center should have blown (like the air conditioner, microwave, etc).
In any case, it would be another case for a hard wired (or dangling) surge supressor.
HAM CALLSIGN - KC3FFW
Old 06-26-2012, 04:31 PM   #6
Thank you Lou for the info... At $300 I was taking about the whole converter. In TN we only have 2 RV parts shops. Camping world one and and mom & pop shop. It was about $289 plus tax. I will pass this info to my husband so he can check all this out.
Old 06-26-2012, 04:39 PM   #7
Herk7769's Avatar
Do you have a 50 amp or 30 amp service?
Old 06-26-2012, 09:10 PM   #8
It is a 50 amp service.
Old 06-26-2012, 09:23 PM   #9
TURBS's Avatar
Sounds fishy.
Old 06-26-2012, 09:37 PM   #10
B47
I should have asked earlier, but did any of your neighbors have any electrical problems that you know of?
led pad
