Old 04-27-2012, 10:05 AM   #1
Newbie
pg_rider's Avatar
Truck isn't powering trailer running lights, but brake and blinker lights work
I'm borrowing a friend's truck to pull my trailer this weekend, and when I plugged my pigtail into his truck the running lights didn't come on. The blinkers and brake lights work, as does the brake cotroller, so the connection is at least partially working.
I "shorted" the running lights by sticking a fuse in my pigtail and they all came on so I know they work. It seems that something is amiss with the truck. Any idea what it could be? All 7 pins at the connection look good. Is it possible that a wire broke somewhere in the truck harness? Could there be a fuse in the truck that ONLY affects those pins on the connection?
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 04-27-2012, 10:15 AM   #2
TURBS's Avatar
Most newer trucks have a seperate fuse for light on trailer.
these fuses are seperate from the truck light fuses.
Did you check the power coming from the truck?
Old 04-27-2012, 01:20 PM   #3
Herk7769's Avatar
Check your Honda's manual. There are seperate fuses for each pin on the plug.
HAM CALLSIGN - KC3FFW
Old 04-27-2012, 01:39 PM   #4
Newbie
pg_rider's Avatar
Actually it's a 2002 Dodge Ram 1500 (I'm borrowing it, as my wife has the Ridgeline). I'll check the fuses -- glad to know that each pin has it's own fuse!
2012 Rockwood 2306
Old 04-27-2012, 01:43 PM   #5
Herk7769's Avatar
2002 dodge ram 1500: this trailer i was towing blew them..fuses..bulbs - JustAnswer
This might help
brakes
