Old 03-01-2016, 09:36 AM   #141
Sheesh, you shouldn't be so hard on yourself.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 03-01-2016, 10:01 AM   #142
Some guy in back...
In my view, it's all just electrochemistry and unless you are a trained lab tech or an experienced, experimental post-doc type, there is going to be some variability! We are talking about a few percent anyway, right?
(you could always do a gage R&R study and see just how capable your hydrometer, the battery and your operator(s) are!)
Cheers
ChateauV10 is offline   Reply With Quote
Old 03-01-2016, 10:02 AM   #143
I wonder what the mods will do to someone that flames themselves?
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 03-01-2016, 10:09 AM   #144
SKnight's Avatar
Check water. Fill if necessary.
Charge. If it goes to float, then disconnect. Check tomorrow when surface charge is gone.
Put batteries in camper.
Camp.
I was a mechanic for the first half of my career, I have dealt with more batteries than I care to think about. What I put above? That's my twice a year battery maintenance routine. If something acts up, the hydrometer comes out. Not before. I feel it's easy to take the charm out of camping when you start worrying too much about hydrometer readings, etc.
Old 03-01-2016, 10:50 AM   #145
Be careful Too Tall, wouldn't want to see you ban yourself.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-01-2016, 11:22 AM   #146
Originally Posted by GearHd6 View Post
I ordered the Duracells. I'm not sure if my store had them in stock because it said "call store" for availability. Even if I have to wait for a shipment I'm in no hurry. There was a disclaimer after checkout saying to bring my old batteries. We'll see how that goes.
I picked up the batteries today. Wow, they're heavy compared to that old group 24. I compared them on a bathroom scale and the old group 24 marine battery was 42lbs and the new Duracells are 65lbs each.
2013 Rockwood 2109S
Old 03-01-2016, 12:34 PM   #147
Also, what is a good gauge cable to go between the two 6V batteries?
2013 Rockwood 2109S
Old 03-01-2016, 12:53 PM   #148
4 gauge.
They can be bought at most stores that sells batteries.
2007 Surveyor SV230
Old 03-01-2016, 12:56 PM   #149
Same as the other cables, probably #6 although on my 335DS they were #4. NAPA has cable and cable ends. I recommend soldering the ends with a torch and rosin core solder.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 03-01-2016, 12:59 PM   #150
Oh that's it? That's not bad. I was under the impression that the battery connecting cable needed to be substantial. Thanks.
2013 Rockwood 2109S
battery
