Old 03-17-2016, 08:07 AM   #201
hammer55's Avatar
never seen solid wire from or to a battery, just sayin
Originally Posted by OldBob View Post
Don't use stranded wire. You need solid battery cable. I got mine at Walmart. They have battery cable in 2, 4, and 6 gauge sizes at reasonable prices. 4 gauge is perfect for the job.
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-17-2016, 08:48 AM   #202
Too Tall's Avatar
I'm pretty sure stranded carries more current than solid?
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-17-2016, 08:49 AM   #203
jkoenig24
Stranded wire WILL carry more current AND, will be MUCH easier to bend and work with.
jkoenig24 is offline   Reply With Quote
Old 03-17-2016, 08:55 AM   #204
SeaDog's Avatar
Actually there is no difference in the current carrying ability of stranded or solid in the same wire size. The difference is in the space required for the wire. Stranded is much larger in physical size then solid however it is much easier to bend and conform to curves and such.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-17-2016, 09:43 AM   #205
hammer55's Avatar
true, electricity flows on the outside of the wire, I have always used motor lead wire, it has a higher amp rating, and it is much easier to work with and makes hooking up motors in the pecker head(motor junction box much easier,,,,
Mark & Annie
Old 03-17-2016, 11:22 AM   #206
Herk7769's Avatar
As I understand it:
In an AC current, current flows along the outside (skin) of the conductor and the depth of penetration is due to the circulating eddy currents (arising from a changing inductance field from the current alternating direction). These eddy currents cancel the current flow in the center of a conductor and reinforcing it in the skin. The higher the frequency of the alternating current, the more pronounced this effect.
Known as the "Skin Effect" you can get more info here:
https://en.wikipedia.org/wiki/Skin_effect
DC current goes through the wire in one direction only; basically an electron gets pushed in one end knocking an electron off the other.
A solid conductor will move DC current slightly more efficiently than stranded of similar gauge. However, for a similar current flow demand (wattage) a solid wire would have to be thicker and thus more inflexible (more like a Buss Bar than a wire). That is why battery wires in automobiles are made up of very thick stranded wire.
To reduce resistance in the connection between 2 6 volt deep cycle batteries, use the shortest heaviest battery cable you can find. O or even OO would be best.
6" AWG 1/0 Red Battery Interconnect Cable 3/8" Lugs Battery Banks
http://www.amazon.com/Battery-Interc...WJ212VKWX5V48M12" AWG 2/0 Red Battery Interconnect Cable 3/8" Lugs Battery Banks
ID:	102145   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 03-17-2016, 12:13 PM   #207
The difference in resistance is very minimal 0 gauge = .00032 ohm/meter. 4 gauge = .00081 ohm/meter.
4 gauge would work just fine between your batteries.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-17-2016, 07:09 PM   #208
Too Tall's Avatar
Originally Posted by Herk7769 View Post
As I understand it:
Amazon.com: 12" AWG 2/0 Red Battery Interconnect Cable 3/8" Lugs Battery Banks, Off Grid Applications DURABLE LONG LASTING ASSEMBLED IN THE USA: Automotive12" AWG 2/0 Red Battery Interconnect Cable 3/8" Lugs Battery Banks
Thanks for the link, Herk, I'm going to order one of those tonight.
USMC 68 -70
Old 03-17-2016, 08:15 PM   #209
Of course,Boondocking is exactly right. For a 12 inch cable at 200 amps, the difference between #4 and #00 in voltage drop is 34 millivolts or less than .3%...and 200 amps is a heavy load. The rest of the system (cable to loads, power panel, solenoids, etc) will drop a heck of a lot more and totally dominate.
By the way, stranded vs solid will add another millivolt for #4 and .3 millivolts for #00. I wouldn't want to even try to work with solid #00 copper.
Now, since the #00 cables are available, might as well buy them but your system probably has 30 feet of #4 or #6 in it anyway between the batteries and the loads...and back!
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 03-17-2016, 09:45 PM   #210
Too Tall's Avatar
Yea, good point. And I don't think I'll ever run anything in the camper that would draw more than a few amps.
USMC 68 -70
battery
