Old 04-30-2016, 07:25 AM   #261
Originally Posted by Burgeogull View Post
Also curious why you're switching back to 12v from the 6v set up?
He's not switching back, he was referring to converting the AH for his 6 v batteries into an equivalent 12 volt series hookup. Each 6 v Trojan is 125 AH, the series connection is therefore 12 V at 125 AH.
Your battery status monitor will always read full when you are charging since it is only reading voltage and the voltage is more than 13.3 volts from the converter or charger when charging. If you wait 12 hours after you stop charging, the panel will sort of indicate the state of your batteries according to the chart that has been posted numerous times on this forum. Not a good way to tell the status since most of us can't wait 12 hours to find out how much we have left in the bank.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 04-30-2016, 09:40 AM   #262
Originally Posted by ScottBrownstein View Post
Funny, but in 15 years on both this and other RV forums, I have never heard anyone say anything good about a WFCO converter. They must have a really good volume price to the RV manufacturers. Now, my Georgetown came with a PD, so hopefully the manufacturers are waking up to the problems.
After reading the WFCO manual, I'm convinced WFCO converters usually work as WFCO intended them to. But usage scenarios vary widely from one camper to the next, and the battery charging needs of one user are not nearly the same as the next.
The WFCOs are liked by the RV manufacturers because they are programmed very conservatively to avoid battery gassing and over-charging. And they use cheaper components, and are cheaper to buy. For example, the WFCO will not go into bulk mode unless the battery is pretty low, and for some users not at all. The WFCO, per the manual, will not go into trickle charge for at least 44 hours at a steady current output. That means that while camping, the WFCO essentially stays at 13.7 volts all the time unless you drag the batteries really low, and can trigger bulk mode. It also means slow recharging on a generator or shore power.
The PD is usually programmed more aggressively, and will go into bulk mode sooner and stay there longer. I believe some PD units can be manually forced into a particular charge mode.
On my A-frame the converter is also the power distribution panel, so replacement of the WFCO is not as easy. For our camping style, the WFCO is adequate. We put in two GC2 6V batteries (232 AH), and that is sufficient for 4 nights with the heater. We don't use inverter, generator, or solar to avoid the hassles of each. But we never spend more than 4 nights in any one place. Put the A-frame in the garage when we get home, plug it in for 3-4 days, and we are ready to go again. KISS camping - I like it.
Fred W
2014 Rockwood A122 A-frame
pgandw is online now   Reply With Quote
Old 04-30-2016, 10:05 AM   #263
[QUOTE=ScottBrownstein;1180499]He's not switching back, he was referring to converting the AH for his 6 v batteries into an equivalent 12 volt series hookup. Each 6 v Trojan is 125 AH, the series connection is therefore 12 V at 125 AH.
Oh!! I see now since I read it right.
My 6v batteries are also 232 ah.
2014 Salem 27RKSS
Burgeogull is offline   Reply With Quote
Old 04-30-2016, 10:47 AM   #264
HONDAMAN174's Avatar
Stupid question. Of those of you that have had 12v batteries and 6v batteries, which have a better life span?
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 04-30-2016, 04:40 PM   #265
I had dual 12V size 24 batteries installed by the dealer when I bought the a-frame new April 2014. One of them went bad April 2015. I ended up destroying the other one before I realized what had happened.
I replaced them with dual GC2 6V Interstate golf cart batteries from Costco ($150 for both including tax). This was cheaper than 12V and gave me 232AH instead of 160AH from the12V. The 6V also fit the battery box better. Only drawback to me for the 6V is 40lbs more tongue weight.
After a year, the 6V are showing 12.8V at full charge.
Fred W
Old 04-30-2016, 07:25 PM   #266
6V golf cart batteries are built sturdier and typically can be discharged more. You can get equivalent 12V batteries but they tend to cost more. Easier to maintain 2 6V batteries versus 2 12V batteries as there are only 6 caps to fill/check.
2015 Ford F150 Platinum 3.5L Ecoboost
2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
mjbenedict is offline   Reply With Quote
Old 05-01-2016, 04:03 PM   #267
I usually got 4-5 years out of 12v batteries. I'm into my 6th year with two 6v batteries, they are still going strong and have a resting voltage of 12.75
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 05-01-2016, 07:59 PM   #268
Too Tall's Avatar
Fred W
Excellent information, thanks. This explained a lot of questions I had on the WFCO.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 05-01-2016, 08:15 PM   #269
John McClain's Avatar
Keep in mind not long a go deep cell batt only came in 6 volt Now you can get them in 12 volt look into the floor sweeper 12 deep cell's made by US Batt.
150 ah out a 31t x2 + 300amp hrs
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 05-01-2016, 08:16 PM   #270
almost half the golf carts run 12 volt deep cells now
battery
