Old 02-24-2016, 11:54 PM   #51
SKnight's Avatar
Originally Posted by Too Tall View Post
It sounds like the general opinion is 6 volt is the way to go but I can't get two 6 volts in my rack, too long and I've got 3 perfectly good 12 volts I plan in connecting in parallel and just sit on the ground while camping. Any problem with doing this?
Not really, just make sure to attach the positive cable to battery one, then parallel battery two, then three, then attach the negative cable to battery three.
You'll likely catch a lot of grief about putting batteries on the ground unprotected, but that's outdated info. Modern cases prevent the grounding out issue batteries used to have. But, you can always get a board to put under the batteries if it's a concern.
Old 02-25-2016, 12:21 AM   #52
Too Tall's Avatar
Thanks, was thinking about build a rack that would mount them, just while on location, above the present batteries.
Regarding two six volts, I looked at some 6 volts that were 230 am/hrs. does that mean two fo them will provide 230 amps at 12 volts?
thanks in advance
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-25-2016, 01:22 AM   #53
SKnight's Avatar
thanks in advance
Exactly right, when you connect two 6V batteries in series you double the voltage, but not the amp hours.
But when you parallel two 12V batteries you stay at 12V but double the amp hours.
I like my 6V batteries, I've got four in a series/parallel arrangement. 12V at 460ah.
Old 02-25-2016, 05:34 AM   #54
I wonder what would the cost difference would be between four six volt T-145 and six T-105. I know the difference in amps, I would get more amps
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 02-25-2016, 09:41 AM   #55
Too Tall's Avatar
Will the stock WFCO converter handle 6 volts (in series) exactly like a 12 volt. Is that resting voltage for the 2 6 volts about 12.7 volts like the 12'?
thanks in advance.
USMC 68 -70
Old 02-25-2016, 10:54 AM   #56
thanks in advance.
2 6 volt batteries is series is exactly the same number of cells as a 12 volt battery. No difference except more capacity per cell.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-25-2016, 07:15 PM   #57
Too Tall's Avatar
So I've determined that I can fit the Century battery box and 2 - 6 volt batteries in it on the tong of my TT in the usual position. Trojan seems to offer 4 different terminals. Which one do you guys recommend?
http://www.trojanbattery.com/pdf/dat...ata_Sheets.pdf
USMC 68 -70
Old 02-25-2016, 07:20 PM   #58
The easiest way is to get the same terminals that your current batterys have.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 02-25-2016, 08:41 PM   #59
Too Tall's Avatar
Great thread. Learning alot. IMO regarding 6v vs 12v, you can get approx. 35% more amp/hrs in the same footprint with 6v batteries. Since my batteries are on the trailer tongue, space is paramount. If i'm missing something, tell me.
USMC 68 -70
Old 02-25-2016, 09:01 PM   #60
PokerDealer's Avatar
I have the same setup.....are you sure you don't want 2 T145 30% more capacity for just a few more dollars.
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
battery
