Old 02-26-2016, 04:03 PM   #71
PokerDealer's Avatar
I thought the external measurement was the same except for height and weight
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
Old 02-26-2016, 04:05 PM   #72
I have enough room for the
T 145's just didn't research it enough, before I bought
Old 02-26-2016, 04:07 PM   #73
Too Tall's Avatar
Originally Posted by GearHd6 View Post
His battery rack sits on top of the frame rails, ours are between the frame rails.
Ah yes, I knew something didn't jive as I've been out there with my ruler and back to the internet for battery dimensions for several days now. thanks.
I thought about welding a rack on the frame top for the purpose but hate to do any welding on the tongue.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-26-2016, 04:15 PM   #74
Too Tall's Avatar
Well right or wrong, I ordered one of these. Hope I'm not sorry but it will fit in my rack and hold the 2 six volt batteries.
Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)
USMC 68 -70
Old 02-26-2016, 04:20 PM   #75
I have the Flagstaff Sofa version of your trailer and that is the exact box I use. It works great for the 2 T105s I have
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 02-26-2016, 04:23 PM   #76
That white box has no strap to hold the lid on?
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is online now   Reply With Quote
Old 02-26-2016, 04:25 PM   #77
Hugh R's Avatar
Nice thread, this is what I did for a battery hold down with some plexi I had sitting around.
2013 Mirada 29SE, I earned it!
Hugh R is offline   Reply With Quote
Old 02-26-2016, 04:27 PM   #78
You can buy some straps at Walmart for 5 dollars. I put 5,000 miles on my trailer last year and the lid is still there.
Old 02-26-2016, 04:42 PM   #79
That's a good idea. I was thinking two battery boxes for some reason. I guess I needed to think outside the "box".
2013 Rockwood 2109S
Old 02-26-2016, 04:50 PM   #80
northstar1960's Avatar
Originally Posted by pgandw View Post
I had dual 12volts. I have proven the hard way that it's a nice fable to think you will be able to take the bad battery out of the circuit and limp along on the good one.
Real life experience is that when one goes bad, you won't know until the good one has mostly discharged itself into the bad one.
The other issue with dual 12V (which I also found out the hard way) is that if the two batteries have significantly different charge states when you connect them together, the current flow between the two batteries in parallel is enough to melt cables and start electrical fires. I'm very glad the batteries were mounted on the tongue.
I have since switched to dual 6V golf cart batteries in the same box. Gives me more capacity (232 AH) and less worries. I bought mine from Costco (Costco-branded batteries rated highly in Consumer Reports) - $150 for both, including tax.
With our style of camping, loss of battery does not necessarily end the trip. The biggest loss would be the heater. We have flashlights, and fridge does not use 12V. Water would be awkward, but we carried water when we tent camped. But our longest camping trips are only a week now anyway.
Fred W
2014 Rockwood A122 A-frame
Don't assume you can't or won't have issues with 6 v batteries . you can find yourself in the same boat with the 6v . I've used 12 volt batteries for 30 yrs . see no reason to switch to 6 volt batteries . i run 4 24 dp 12 v batteries and in 30 yrs have never had issues like you describe . one plus note on the 12'ves is you can get by with just one . I often use one as a trolling motor battery something you won't do with a 6 v . the one time i did have a 12v go bad it did nothing to the others i just removed it from the set up and kept on going . no need to run to town .I guess the first thing one must do is pay better attention to there batteries . most all wait till they have issues .
northstar1960 is offline   Reply With Quote
battery
