Old 03-14-2016, 09:13 PM   #181
Batteries that are in the 50% to 80% charge state can be safely recharged at a rate equal to about 20% to 25% of their capacity.
If you have a battery bank 232 AH capacity (my two 6V batteries) that has been depleted below 80% charge, they can be recharged at about 46-50 amps without overheating and excessive gassing of the batteries. So a converter bigger than 55 amps (to allow for other DC loads) is a waste of money.
To use the capacity of a 70 amp converter would take a battery bank of around 300AH or more.
At the other end, if you only have a single Type 24 12V battery (80AH), any more than a 30 amp converter is a waste.
Recharging from 80% charge to 100% charge is a slow process, that slows even more as you go above 90% and approach 100%.
So often heavy battery users with periodic recharging will run their batteries in the 50% to 80% range to allow fastest possible recharging while keeping battery life reasonable.
Fred W
2014 Rockwood A122 A-frame
pgandw is online now   Reply With Quote
Old 03-15-2016, 08:39 AM   #182
Herk7769's Avatar
Fred is correct when considering the amperage spread evenly in a battery bank (wiring of the batteries must be balanced electrically) and no single battery is exposed to that kind of amperage.
Some additional thoughts:
1) A converter will power the DC needs of the camper first and provide charging amps to the battery second. The higher the DC needs of the camper, the less amps available for Stage 1 charging.
2) The chemical reaction that takes sulfates deposited on the battery plates during discharge and forces that back into solution is an exothermic reaction; it generates heat. That heat can cook off the water in the electrolyte. Lower charge rates; less heat generated.
3) The high charge rates of Stage 1 (called "Bulk" among other names) requires a battery discharge state below 50% in order for the battery plates to have enough "holes" on the surface to force charger electrons into. Using this Stage will cause a lot of heat internal to the battery and can cause a permanent loss of capacity and reduce the total charge/discharge cycles the battery is capable. See attached graph of the total cycles possible based on the depth of discharge before recharging. Stage 1 is a pretty violent way of charging a battery and is to be avoided if possible. FYI - Cycles on the Vertical and Depth of Discharge on the Horizontal.
4) Once those "easy holes" are filled (at about 50% capacity), the charge rate must be cut back to under 10amps to avoid "boiling" the electrolyte and permanently damaging the battery by plate warping or cracking. Called Stage 2 (or Absorption), a converter, no matter how many amps rated, will only charge about 8 - 10 amps once the battery reaches 50% charge.
5) At 90% of capacity, nearly all of the remaining useful "holes" have an electron in it. Finding a vacant one is more difficult so the charge rate again must be reduced to a rate that matches the time the electron takes to find a "home". This is charge stage 3 (or Float). In float, the charge rate is reduced below 2 amps (again regardless of available capacity to deliver). It will stay in Float until the battery will no longer take any more electrons. This process can take several days.
6) Since high charge rates permanently reduce capacity and can damage the battery, it is recommended that you never discharge a deep discharge battery below 50%. This number is in all the literature and now you know why.
7) Using an inexpensive dedicated 10 amp (or so) battery charger-maintainer to maintain your 50% or less discharged battery when boondocking, puts less wear and tear on your expensive converter and will require the exact same time on your generator.
8) Using that 10 amp dedicated charger will take longer to charge a more severely discharged battery but it will cause less long term damage than Stage 1 (28 amps or so is all you are going to get anyway before a current limiter opens at 30 amps - most towable campers).
As an aside, the standard 4 light battery condition indicator system used in all campers will indicate the battery has fallen below 50% when the 2nd light from the top goes out. As a refresher, the top light is "charging" (not full), the second is "good" and will stay lit until the battery needs to be recharged. The 3rd light is "Fair" and will stay lit until the battery is actually dead. The fourth light will always stay on until that battery (or batteries) needs to be replaced due to failure.
Name:	battery Life as a function of charge discharge cycles.jpg
ID:	101978   Click image for larger version
ID:	101979   Click image for larger version
Name:	Battery Display.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 03-15-2016, 01:48 PM   #183
So what you are saying is a 30 amp charge and a 10 amp charge are both going to take the same amount of time to charge a battery.
That just doesn't sound right.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 03-15-2016, 02:43 PM   #184
Actually, what he is saying is that at some SOC level, the 30 amp converter will only be putting 10 amps into the bank as it comes up to charge. At that point, both the 30 amp (or 40, or 50 or 70) will only be putting 10 amps into the batteries and it would then be equivalent to a 10 amp dedicated battery charger. However, that is why I have the pendant on my PD9270, so that I can force it into boost mode when running the generator to maximize the value of generator run time. Before we get all crazy about overheating the batteries at 14 or 14.5 volts in boost, remember that the alternator generally runs at 14 volts or little more anyway.
However, I do not subscribe to the"wear and tear" argument. In addition, most 3 stage converters also have a 4th stage "equalization" pulse mode when in storage mode that keeps the electrolyte mixed every so many hours. a conventional charger won't do that.
To go beyond just theory and conjecture, I am installing small automatic data logger that will connect with and log my Trimetric in real time to a micro SD card. Once I have that, all of these questions will be easily answered with real data that can show SOC, voltage and current from loads, converter, alternator and solar in real time at relatively high resolution. In addition, it should also allow me to compare battery SOC bank vs resting voltage as my batteries age going forward. Analyzing the Trimetric log data will pretty much tell you how well everything is working in an RV electrical system.The meter display is great to tell you what is happening at a given instant, but knowing what happened for the past days and weeks as the RV is used will tell all!
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 03-15-2016, 02:46 PM   #185
What is this "pendant" you speak of. I'd love to be able to force my WFCO into bulk mode while running the generator.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 03-15-2016, 02:59 PM   #186
Unfortunately, you can't add one to a WFCO converter, only to Progressive Dynamics converters. Time will tell what it is worth for me once I can see what is actually going on. My converter is a 70 amp unit and I can force it into boost when I run the generator, but the 22 feet of #6 wire between the converter and the batteries costs me some voltage and therefore charge current. I am perplexed that FR used both a positive and a negative cable to go to the batteries when they could have saved wire (and half of the voltage drop) by simply grounding the negative from the converter to the chassis in the rear power bay. That is an easy fix however, but I won't mess with it until i can see what is really happening over time.
There is also some data that indicates that some RV power converters don't do so well when running on the strange AC waveform that comes from Onan generators vs connecting to shore power.
We'll see.
2015 335DS
Old 03-15-2016, 03:08 PM   #187
Until it gets to 90% SOC the higher amp rated charger should bring it up quicker to that point thus reducing generator run time. Right?
2007 Surveyor SV230
Old 03-15-2016, 03:10 PM   #188
stupid question, what happens if my charger was unplugged from DEC until now. How will this effect my 2 6 volt batteries
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 03-15-2016, 03:16 PM   #189
bikendan's Avatar
If you have no battery disconnect switch, then they might be dead.
Old 03-15-2016, 03:17 PM   #190
If everything was turned off and your batteries were charged you should be down a bit, but get it plugged back in and charging. lead acid batteries only lose 2 to 5 percent charge per month when sitting, less if its cold.
2015 335DS
Old 03-15-2016, 03:32 PM   #191
thanks, i pulled them from the trailer, have them sitting in the basement out of the way. Apparently out of the way also includes not being charged
Old 03-15-2016, 04:23 PM   #192
Certainly it will be better until some SOC level, hard to say exactly what as that will depend on your converter but I will find out the story for mine. But some of this is really overblown. There is really no reason to go to all of these great lengths with manual adjustments and connections. Get a good converter, make sure the batteries are watered, make sure that everything is working and keep your SOC is between 50% or 80% and 100%. I will telll you that it takes a long time to get the last 5 or 10 percent, which is why solar is so helpful. A Trimetric will tell you where you stand at each and every moment. Getting low, run the generator or plug in. In your case with solar, enjoy the sunshine and watch your SOC climb back all the way up.
This isn't black magic, but with only the 4 little red LEDs on the panel, you really don't know where you stand at all.
All you have to do beyond that is enjoy your RV.
2015 335DS
Old 03-15-2016, 09:40 PM   #193
Too Tall's Avatar
Is a #4 strained wire heavy enough to connect the two 6 volts in series? Or maybe I should also be asking if #8 is heavy enough for the converter to the batteries about 10' distance.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-15-2016, 09:44 PM   #194
Kenny kustom's Avatar
You can find a 4/0 ga 17" battery connect everywhere.
Easy and thick.
I would use as big of wire from the converter as you can fit into it.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-15-2016, 09:54 PM   #195
Too Tall's Avatar
Easy and thick.
2016 Sabre 36QBOK
Thanks Kenny, that's what I've got on it now. Seems to be ok. I'm think the most amps will be while charging with the generator and the onboard converter.
USMC 68 -70
Old 03-15-2016, 10:19 PM   #196
Herk7769's Avatar
What I am saying is that a converter in Stage 2 and a 10 amp dedicated battery charger will charge a deep cycle battery to float in the same amount of time.
Old 03-16-2016, 12:48 AM   #197
Don't use stranded wire. You need solid battery cable. I got mine at Walmart. They have battery cable in 2, 4, and 6 gauge sizes at reasonable prices. 4 gauge is perfect for the job.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 03-16-2016, 05:22 AM   #198
Since you are using the studs for your trailer, leaving the posts open.
http://www.picocanada.com/en/product/6247.php
2016 Sabre 36QBOK
Old 03-16-2016, 08:03 AM   #199
There is a nice DC table at http://assets.bluesea.com/files/reso...on_chartlg.jpg
I would consider the converter "critical" as voltage drop reduces charge current and lengthens recharge time. Unfortunately FR did not do this with my converter which is a 70 amp unit and is 22 feet from the bank and is wired with #6 S/B at least #4 and perhaps even #2. At least they could have grounded the negative to the chassis to cut the drop in half.
All of my "inter battery" cables are #4, most auto supply stores sell #6 but those cables are not for RVs. They are very short, however, so the voltage drops are minimal.
You do have to be sensible here, a 70 amp converter will spend a small portion of its lifetime trying to output 70 amps.
2015 335DS
Old 03-16-2016, 11:15 AM   #200
Too Tall's Avatar
Yes, thanks, I'm going to check my wire size and length today
USMC 68 -70
battery
