Old 06-14-2016, 02:28 PM   #1
Cut_un's Avatar
TT battery?
We have a MicroLite 21 DS , it came with a brand new battery.. Has been sitting in the yard for a week.. I charged it when we got home from our last trip. Because we are leaving again in the morning, figured I would check & charge again today...,if needed I is charging at this time and sorry to say, now a 50%??? Is that normal?? We have not used it, other than putting the slid out when we got home????
Cut_un is offline   Reply With Quote
Old 06-14-2016, 04:06 PM   #2
northstar1960's Avatar
there are drains on the battery even when not in use like the co detector . the best thing to do when storing is use the battery disconnect . if you don't have one then you may want to install one .
northstar1960 is offline   Reply With Quote
Old 06-14-2016, 04:16 PM   #3
bikendan's Avatar
If it's a newer unit, should have a factory disconnect switch.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-14-2016, 04:33 PM   #4
Look under the tongue in front of your battery. Big red key.
2011 Traverse LT, 3.6L, FWD
Old 06-14-2016, 07:34 PM   #5
Cut_un's Avatar
Thanks... Found it!
battery
