Old 03-11-2014, 06:54 PM   #1
TT battery help. Please
I bought a new Forest River Salem 27RLSS. I have had it a week Saturday when I brought it home I plugged it in to electric at my house via an adapter and ext. cord. When I came out two days ago all lights were dead and the new battery was dead so I disconnected it and charged it up and re connected it and all lights and stuff came on now today again the battery is dead. I have checked the fuse and breaker panel inside and all is good. I also checked the ext. cord and outlet. What else can I do?
Hermanbilly is offline   Reply With Quote
Old 03-11-2014, 08:04 PM   #2
HONDAMAN174's Avatar
Do you have a battery cut off switch?
Just glad to get away
Old 03-11-2014, 08:06 PM   #3
Not that I am aware of. I will double check.
Thank you
Old 03-12-2014, 06:30 AM   #4
I could not find any cutoff switch I also checked in the manual and see no mention of it.
Old 03-12-2014, 06:53 AM   #5
Dave Lyon's Avatar
A new FR trailer without a battery disconnect.....seems odd. Mine is a push/pull switch located right beside the charger.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 03-12-2014, 06:55 AM   #6
Arefbee's Avatar
It sounds like you don't have power to the extension cord. When you are on "shore" power you should have lights even with a dead battery.
Start out simple - check the cord is delivering power, then take a look at breakers.
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 03-12-2014, 07:00 AM   #7
Dave Lyon's Avatar
a quick way to confirm that you have AC power, upon hook up is to look at your microwave.......if there are no numbers flashing, you have no AC power to the trailer.
Dave, Southern,ON
Old 03-12-2014, 07:18 AM   #8
mjones12's Avatar
Not really. I bought new 2010 and 2013 Surveyors and neither had a battery disconnect. Easy to install one, though.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 03-12-2014, 07:23 AM   #9
TURBS's Avatar
2012 and up they started installing disconnects at the factory.
To the op
This is not a disconnect issue.
There's either no power coming into camper or there's no power from the outside connection to the converter.
Are you plugged into a gfci in your house?
If so this may be your problem.
Have you also checked your circuit breakers in your house ?
Have you checked your circuit breakers in your camper?
TURBS
Sabre owners united!
Old 03-12-2014, 07:31 AM   #10
mjones12's Avatar
To the op
TURBS
Not on my 2013 Surveyor 220. I imagine it varies from model to model.
Old 03-12-2014, 08:44 AM   #11
I checked the cord I have power going to the camper and the microwave works I am getting 110 to it. It's not charging the battery are giving it 12v power
Old 03-12-2014, 08:46 AM   #12
To the op
TURBS
Yes I checked the house breakers and I am not on a gfi circuit and I checked the ext. cord and tried other outlets and cords. I have also checked the breakers in the camper and fuses.
Old 03-12-2014, 08:48 AM   #13
Old Bones's Avatar
I haven't seen one on our 2013 Surveyor SP 296 either.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
Old 03-12-2014, 08:48 AM   #14
Always Learning
Nor on my Sabre. I know they're doing it now, I have a picture from my factory tour.
Old 03-12-2014, 08:50 AM   #15
TURBS's Avatar
What model and make converter do you have?
TURBS
Old 03-12-2014, 08:56 AM   #16
Dave Lyon's Avatar
I wouldn't put too much time or labour into this repair, outside of visual insopection and breakers. I wouldn't start tinkering with the converter.
You mentioned that the trailer is new, I assume you have full warranty.
Let the dealer make the repair under warranty, if it happens again, at least you have a paper trial.
Dave, Southern,ON
Old 03-12-2014, 10:02 AM   #17
That's what I was trying not to do this week my dealer is a hour away and I am working all week and have reservations at the lake this weekend for 3 days it is my first trip not out to a good start. Is there a way to bypass it for the weekend?
Old 03-12-2014, 10:06 AM   #18
Chuckinca's Avatar
Our charged RV marine battery never stayed charged very long even when only using it to run a light or two.
It's basically shore power or forget it.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 03-12-2014, 10:10 AM   #19
I have tried but without the battery I have no 12v power at all.
Old 03-12-2014, 10:11 AM   #20
Ok. When you can, let's check the connections to the battery, check the ground connection to the frame, and look for an inline fuse from the battery.
battery
