Old 04-06-2013, 10:03 PM   #1
Turn signal
Hello everyone,
It is time once again to pull out the rig and test out the systems. I have a 2006 Rockwood 2603. When testing the lights I have all running lights, brakes, and left turn signal. The right turn signal is the only one that doesn't function. I have checked the circuit to the plug on the tv and it all checks out. I think it may be a problem with the ground but am not sure where to go from here. I know someone on this forum can help me.
Fireman2 is offline   Reply With Quote
Old 04-06-2013, 10:42 PM   #2
Quite often corrosion will build up in the socket which prevents the bulb from making a good ground contact. Try removing the bulb, taking a small piece of fine sandpaper to scour the inside of the socket, spray with a little WD-40. Usually that will fix it.
Sirsea is offline   Reply With Quote
Old 04-06-2013, 10:56 PM   #3
Dave_Monica's Avatar
If you have a brake light on that side, the turn signal problem isn't the bulb. The problem may be in your 7 pin plug. Try spraying WD40 on both sides of it.
Dave
Old 04-06-2013, 11:48 PM   #4
Turn signal
Thanks or the advice. I looked at the contacts in the soket and they are clean. The sides however are corroded. I will give everything a good shot of WD40 tomorrow and see what happens.
Old 04-06-2013, 11:58 PM   #5
puff's Avatar
I coat everything with dielectric grease, get some from Canadian Tire. Plugs, sockets, etc...
If your cleaning things make sure your power to that circuit is off or you could start blowing fuses. Somewhere on your truck and trailer frame there should be a black wire, most often thats the ground and they just rust, faster if your closer to the salt water.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 04-07-2013, 05:10 AM   #6
Herk7769's Avatar
Just replaced my right assembly due to corrosion in the socket to pass inspection (too dim). The left one will get done today.
HAM CALLSIGN - KC3FFW
Old 04-07-2013, 06:53 AM   #7
Phat Phrog Stunt Crew
elind's Avatar
Also check the fuzes under the hood of the TV. All of the trailer wiring has separate fuzes from the TV.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 04-07-2013, 08:42 AM   #8
Herk7769's Avatar
You might have missed the "too dim" clue.
There was voltage just not enough ground.
Old 04-25-2013, 12:53 PM   #9
Thanks for all the advice. I took out the bulbs, cleaned the connections and sprayed them down with WD40. Everything works perfectly.
