I managed to do some more troubleshooting between rain bands and here is what I found:
Just for giggles I decided to start with the right turn signal on the trailer( I had to start somewhere
, I removed the LED bulb and put a brand new 1157 bulb in the socket, then I turned the right turn signal on and everything worked the way it's supposed to work.
Then I removed the bulb and put the LED bulb back in and all of the lights blink. I then pulled the LED bulb out of the left signal and put an 1157 bulb in it and nothing changed, all the lights were still blinking.
I went and removed the LED from the right side, put the regular bulb in and the lights worked properly, Then I pulled the bulb from the left side and put the LED from the right side into the left signal and all the lights blink.
I think I can safely say that the problem is a defective LED bulb, hopefully Amazon will send me a replacement, if not I'll just order another complete set so I'll have a spare on hand.
Now all I've got to do is figure out why the LPG detector isn't working, I just installed a new one last week (man are they expensive), and no fuses are blown.
This is my first 5ver and I'm finding out how steep of a learning curve these things require when it comes to fixing things.
Thanks for all the help and ideas on figuring out how to troubleshoot and fix the lighting issue.
