Old 05-03-2015, 12:26 PM   #1
Turn Signal problems
I have a 2014 36 CKTS 5th my left turn & break ligts quit, is there a fuse in the camper & where is it, gettting power to plug & lights are LED???
carlt is offline   Reply With Quote
Old 05-03-2015, 12:30 PM   #2
Ford Idaho's Avatar
Both sides will be hooked to the same fuse so if the right side works then the left side has an issue of it's own.
Pull off the lens and check the bulb and the light socket for corrosion.
Also check that there is power to the socket.
Old 05-03-2015, 02:07 PM   #3
Bulb is LED no power there why I thought fuse, mystery!!
Old 05-03-2015, 02:20 PM   #4
Ford Idaho's Avatar
Does the bulb work in another socket?
Anything happen to the pigtail lately?
Has the unit had any work done that required screws or nails to be removed/added on the none working side?
Old 05-03-2015, 02:23 PM   #5
mcnabbwr's Avatar
Make sure your plug is clean and free of corrosion. Test your TV socket for voltage when signals turned on. Good luck.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
