Old 12-03-2015, 12:12 AM   #21
Originally Posted by TURBS View Post
I leave my unit plugged in 24/7 365.
Converter "4 stage" is also up and running and charging batteries.
More often then not my whole system is drawing 1 amp when I look @ the ems panel.
what converter do you have? done any mods? my stock wfco never hits the maintain stage.
poorbuthappy is offline   Reply With Quote
Old 12-03-2015, 05:46 AM   #22
TURBS's Avatar
Just a proggresive dynamics unit.
I have a 4 stage converter to replace that junk wfco if interested.
This one.
http://www.bestconverter.com/55-Amp-...l#.VmArZlnnbqA
Old 12-03-2015, 12:14 PM   #23
Solera Converter off??
OK, I did something dumb - went to fuel up and forgot to unplug from shore power Now, I was heading to Florida and discovered no lights, control panel, etc while driving. Hooked up at a campground overnight and of course all then worked - the panel showed fully charged batteries. From the discussion on this original question, I believe the converter is not running. Can someone help me as to where the converter circuit breaker or fuse is located on my 2012 Solera??? Thanks!!
RSolera is offline   Reply With Quote
Old 12-03-2015, 12:48 PM   #24
2012 Solera
On our 2012 Solera "S" it is in the black plastic fuse/breaker box below the stove. "Finger nail" slots to pop cover. Think it was second, third or fourth breaker from the top. Turn completely off, then back on. Also controls the 110 volt outlet above and behind the driver seat. I check that outlet to see if the breaker has tripped.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 12-03-2015, 01:36 PM   #25
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by 05CrewDually View Post
As far as I know there is no "switch" or fuse you can pull to kill just the inverter but keep the 110v on because they are directly integrated.
My Rockwood TT has a separate breaker for the converter.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 12-03-2015, 02:16 PM   #26
Battery Control Center
Thanks to those who replied, but there were no tripped breakers or blown fuses. There is a black panel to left of steps called a "Battery Control Center" where there was a tiny reset button which somehow had been tripped. Flipping it corrected the battery problem!! Hope my mistake helps others
Old 12-04-2015, 12:32 AM   #27
This one.
been thinking about doing that boondocker one... but for the stock one, the best way to kill batteries is to think it does it's job right.
110v, converter
