Old 05-29-2014, 04:34 PM   #1
TV Antenna Will Not Turn On - New Sandstorm
Just wondering maybe I'm missing something here. When I went to watch tv the antenna wouldn't turn on. It's a new trailer. Is there something I am doing wrong?
Sent from my SM-N900V using Forest River Forums mobile app
Kojack1 is offline   Reply With Quote
Old 05-29-2014, 04:54 PM   #2
Herk7769's Avatar
What do you mean "the antenna would not turn on?"
Are you saying that when you press the selector button the green light will not turn on?
HAM CALLSIGN - KC3FFW
Old 05-29-2014, 08:39 PM   #3
No its actually the signal receiver that's not getting any power so I have to play hit and miss with the antenna position. The tech support from Jack Free TV says I might not be getting any power or I have a bad control panel.
Old 05-30-2014, 05:14 AM   #4
Herk7769's Avatar
So, a couple of things to try.
1) Take the panel off the wall and remove the cables (note what goes where!) but not the power connectors. Toggle the faceplate button to see if the switcher powers up (light comes on). If so you have a short in an antenna cable or in the Jack's Amp (inside the antenna head).
2) If it does not power up, check for voltage at the V+ terminal. If not, check for voltage using a different ground (black wire terminal to frame). If it works you have a bad ground connection and you will need to follow the black wire to where it screws to the frame. If 12 volts is available, replace the wall switcher. Check out Winegard's new one!
3) If you confirm the ground is good and it still won't power up, there is a fuse that protects the switcher in or near the power center. It may be behind the power center on a pigtail fuse holder (mine is). If the fuse is good and there is power there; you need to find the break in the wire or run a new one.
Old 05-30-2014, 06:26 AM   #5
Retired Trucker/43 years
Noneyerbusiness's Avatar
Seems those "Jack" antennas cause more problems than they are worth? My Winegard (manual), works everytime .. Just sayin ...
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
Old 05-30-2014, 06:32 AM   #6
Herk7769's Avatar
Jack or Winegard, both have powered amps in the white box at the top.
antenna
