04-09-2016, 08:54 AM
TV charging camper batteries
Hello everyone,
We just became the proud owners of a 2016 2504S and I have a newbie question. So far I have upgraded from the single group 27 that came with the camper to three group 31 DP batteries that I got from work at a good price. Here is my question: if the camper battery(s) are way down after say a weekend without A/C hookups and you plug the camper int the TV and start the engine, what keeps the #12 gauge charge wire from the truck from burning up when there is a 140 amp alternator on the other end? What should happen is when the truck senses a big load like 3 batteries run down the alt should put out a lot of amps to try and bring the voltage up to 14. Because the load is the camper why doesn't the wire get hot and burn? The only other experience that I can think of is jump starting another car with cheap cables, they never got hot. Thoughts? Thanks in advance. Jay
04-09-2016, 09:05 AM
There is usually a resettable breaker ( on trailer) should the current get too high. There is also a fuse in the 12V TV fuse block for the Aux line.
You will get virtually no usable charge on the batteries by running the TV ( idle). You can get some minimal charge while driving, but due to parasitic loads in the RV and the wire size and length, the voltage delivered to the batteries will not be enough to make a significant impact on the charge. For that setup, you will need to plug into shore power, Plug into a generator, or add solar.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-09-2016, 09:27 AM
You could run welding cables back to the batteries but that would be expensive. If I could afford it I would put solar in, that's the best way to go, again just expensive
04-09-2016, 09:42 AM
It seems unlikely to me that your truck would damage itself. You just don't hear about burned up charging circuits. You would have to drive at highway speeds for a couple of days to do anything to a battery bank like that.
The big banks are nice for additional capacity but the down side is that it takes a lot longer to recharge as well. No free lunch. Amp hrs out and Amp Hrs back in. And charging is less efficient than discharging. So, it will take more Amp Hrs in to replace a given amount of Amp Hrs out.
You should install a serious battery monitor, like a Victron, so you know what is going on with your battery bank.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
04-09-2016, 09:55 AM
All I can go by is what we have as the factory charge circuit in our current TV. It would take a long time to charge a battery as it was only designed to maintain a charged battery and light electrical load. I haven't been able to find the factory spec for the pin 4 wire as it is missing from all of the connector pages but it looks be only 16 or 18 ga. Due to this I am adding my own higher current line to provide power to the TT while towing.
04-09-2016, 10:11 AM
Look at the size of the fuse for that pin in your tow vehicle's fuse box. That is the most your TV will EVER be able to deliver to your camper. My 2008 GMC Sierra is fused at 40 amps. That is a lot of amps possible, but in reality you will never see that much going to your camper's battery because the alternator's charge circuit will cut back on charging volts/amps when your truck's battery gets full (a lot earlier than your discharged camper battery bank).
See the attached about why vehicle alternators make lousy deep cycle battery chargers.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-09-2016, 10:13 AM
Before you spend a lot of money doing this, please read my post.
You would need a dedicated alternator as well that did not connect to the truck's battery.
Our batteries were at 3/4 after a day of boondocking, we unhooked the truck to go check out the area and left the trailer at camp. When we got back I connected the truck (w/2 group 78) to the TT and that brought the batteries back up for the next day. When we left the tt batteries were again down to 3/4. Once we got home, a 3 hr drive the tt (2- group 24) batteries were fully charged.
On my 5 ton dump trailer it uses a battery to lift the box. I have popped the 40 amp trailer fuse in the truck fuse box a couple times due to the battery getting old and weak. Otherwise with a good battery it recharges within 1-2 hours of driving ready for the next dump run.
TT- 2016 Grey Wolf 21RB
TV- 2004 GMC3500 4x
04-09-2016, 10:40 AM
Already been through the schematics with the dealer and Ford. The dealer told me they have had to do a similar thing for another customer who needed more current for their trailer. Ford changed the circuit in 2015 F-150's to charge off the PCM which drives a few other thing too and is fused at 20A. Ford explicitly told me that pin 4 is only intended to maintain the battery and not charge it. I was able to get the gauges of the all the other wires going to the 7-pin connector. It is looking at this chart and comparing pin 7 to the other wires that I came up with 16 or 18 ga. Neither of which are good for much current over the roughly 30 ft of wire from the front to the back of the truck.
I'm not running the new line just to charge the battery but to be able to run the 12V heater on my fridge along with some other things we keep on. Since we run off shore power I have never bothered upgrading the group 24 battery as it does a good enough job keeping things going for gas stops or lunch breaks. This all worked fine in my previous TV that I wired for towing myself and should be just fine after I run a new 8 ga line to the back for the 12V line to the trailer.
04-09-2016, 10:53 AM
You might consider adding an ignition actuated relay to the circuit you are adding. This will prevent killing the TV battery if you park for a few hours with fridge etc running. Many of the large TVs have such a relay in the Fuse block.
TST Tire Monitors
2 100W solar panels
04-09-2016, 11:02 AM
I have the relay, circuit breaker and piggyback fuse holder for the relay low voltage coil. The only real problem I have been running into is finding a place to mount everything neatly. The F-150 is a lot tighter in the engine compartment than my old Explorer was.
04-09-2016, 11:05 AM
Glad to hear it worked out for you.
I just remembered we discussed this some time ago.
As you described, the alternator should see the draw going to the powertrain control module (plus wire to the camper battery) as required "truck load" and not a battery charging requirement.
Did they happen to say what the result of that constant drain into the camper battery will do to the camper battery? Without moderating the charging current as the battery "fills" won't you get a lot of off gassing and electrolyte "churn"?
04-09-2016, 11:32 AM
Thanks everyone for the quick and very knowledgeable responses. I work on semis for a living, as the one in the shop who does the wiring. Sounds like the first thing I should do is check to see how Chevy powered the hot pin on their 2014 models. Defenlatly don't want to share a 20 amp fuse with a PCM. I'll post back when I find out. Thought about running a decayed wire fron the trucks batterys just to charge up the trailer and not go through the plug at all. I have plenty of 4 Awg wire to do the job,also 8 gauge if I want to run that. I like the idea of an ign relay to not let the camper run down the TV batteries. Even then you are only getting the AVERAGE voltage of the TV and TT to tell the alternator what to do. Is it possible that the truck uses a small wire to the trailer plug to limit the max current? Jay
04-09-2016, 11:35 AM
Left Coast
There was a tent camper in Quartzsite this year that had an INVERTER wired into his small pu and when at high idle, he used an external battery charger to replenish his night lights battery used inside tent...
It's been better than a month since I was at the dealer but the PCM I refer to is not the powertrain control module. I don't recall seeing anything other than PCM# but one of it's functions was to provide and manage the charge line (i.e. some type of smart charging is involved). When we were talking to Ford it was a lot of we don't publish that and treatment of everything as a black box. I also know it is tied into the trailer software in the truck based on some things that happened as the trailer battery discharged and tried to keep things running in the trailer. I'm pretty confident in what I'm doing. While I spent most of my pre-retirement career as a software engineer I started off as an EE. I just wish it was easier to get information and schematics like the good old days.
My main thing not knowing what the OP was driving was for them not to assume the charge line was like those on many older vehicles that supported a higher current or would actually charge a battery decently. Rather than make a generic statement I used my TV as an example. To be frank I would not be surprised as more stuff comes under control of vehicle computers we will see more things like what I have popup.
04-09-2016, 11:45 AM
I don't think that is the reason in the F-150. Since they do not intend for it to be a high current line they didn't need to spend money on a larger gauge wire.
04-09-2016, 01:31 PM
I know what you mean by electronics taking over. It now takes two computers to operate the left turn signal in a Kenworth. What I was wondering in the OP was why doesnt the small charge wire in the TV harness overheat and why wasn't a bigger wire run from the factory. On a 2014/15 Chevy/gmc 1500 there is a 30 amp fuse in the underhood fuse box and a clean wire back to the plug. Red with Green stripe. Looked this up online and went out to the truck to confirm this. Fuse #2.Sadly it's snowing here. So the MOST I would get out of the charge wire would be 30 amps before the fuse blew. I also don't think that low camper batts. Would blow the fuse. It would take a shock type load like when the motor is engaged in a dump trailer. On my TV at least if I were camping with campsite A/C and I left the truck plugged in, the converter would charge the truck also. I am going to cut the wire for the fridge heater to help with the situation. Jay
04-09-2016, 09:22 PM
I wonder how you knew the batteries were fully charged?
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
04-10-2016, 08:36 AM
WW
When we got home I checked them, unplugged from the truck for a couple hours and they were at 12.81v. All my batteries are new so probably best case. (the original AC Delco's lasted 11 years.) The 04 came set up for the trailering and since it's a Duramax two batteries and high output alternator.
TV- 2004 GMC3500 4x
04-10-2016, 08:58 AM
You need to understand all things today are computer checked, and that means that all power from something like the TV alt will be monitored by the computer to stop any fire issues (at least in theory) BUT you have a bigger issue, your TV alt will not be big enough to charge all those battery's, it was never designed to charge that much, you really need to have a real battery charger to be able to recharge that much of a system. You also need to check which "converter you have" as it also might not be rated for your battery bank, or might have a very low end charger and ruin your great deal from work. SO you need to do some more homework on your hole system before going any further as the recharge part at thin point is not going to cut it.
Hope this helps and Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
