Old 03-18-2016, 02:01 PM   #1
leefl's Avatar
Twist lock extension cord ?
Hi,
I'm in need of a 30A extension cord for a big trip this summer ("just in case").
All of the extension cords that I've seen go between the plug end of the existing cord and the supply post, with mating plug/socket.
While these would work just fine, it bothers me that there's nothing covering the mating surfaces of where the normal supply cord plugs into the extension cord.
I was wondering if there are any extension cords that use the same twist-lock connector that connects the supply cord to the camper ?
So you'd plug (and twist lock) the extension into the camper, and then connect the other end to the normal supply cable (which would also make use of the twist-lock connectors), and then just plug the normal cable into the supply post.
Seems that with the twist-lock connectors it would all be much more secure, and rain resistant.
Hope that makes some sense
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 03-18-2016, 02:08 PM   #2
caper's Avatar
If you want to keep the connection off the ground and water proof just use a 5 gal pail. Cut holes on opposite side and plug in cord turn bucket upside down now your cord is off the ground and out of the weather (easy fix).
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-18-2016, 02:22 PM   #3
leefl's Avatar
Nice "hack"
Old 03-18-2016, 02:24 PM   #4
leefl's Avatar
This is *almost* what I was thinking of
Amazon.com : Marinco 50SPP PowerCord PLUS Marine Electrical Power Cordset (30-Amp, 50-Feet) : Boating Shore Power Cords : Sports & Outdoors
except that it doesn't look like the socket end would latch with the lock from the existing cord
I believe I'd basically need a NEMA L5-30P to NEMA L5-30R male to female extension cable with Hubbell twist lock on both ends of the cable (one locking ring, one locking receptacle). Perhaps such a thing doesn't exist for some strange reason
Old 03-19-2016, 07:46 AM   #5
cpaulsen's Avatar
Use the regular 30 amp extension cord......I have done it before.....dialectic grease on the prongs........then wrap it with duct tape...had mine on a piece of short 2x6 board for 4 months....with no problems
cpaulsen is offline   Reply With Quote
Old 03-19-2016, 11:26 AM   #6
bob213's Avatar
Actually if you look up dielectric grease you will find it is a NON conductor. Best product to use is Noalox.
Ideal NOALOX 4 oz. Anti-Oxidant Compound-30-026 - The Home Depot
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 03-19-2016, 11:32 AM   #7
Wolverine 1945's Avatar
If what you want is twist lock,,, go to your local Ele Supply House,,, they will have several different twist lock connecters !!! You may want to take your cord with you to make sure you get the right one !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-19-2016, 11:49 AM   #8
KMANUEL74's Avatar
That is the same cord I use for my Rockwood Roo, except I think mine is 75 ft.
KMANUEL74 is offline   Reply With Quote
Old 03-19-2016, 12:39 PM   #9
I use a Marinco adapter. It has the 50 amp twist connector for the trailer on one end and a 30 amp rv plug on the other. It is about a foot long. Works great. Use it with a 25 foot 30 amp rv extension cord. Saves dragging out the big cord. I use it for all 30 amp hookups.
Harkerr is offline   Reply With Quote
Old 03-19-2016, 12:45 PM   #10
Oaklevel's Avatar
You can get twist locks at electrical supply houses but there is really no need.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
