Old 08-03-2015, 05:48 PM   #31
The draw circuit shows zero amps after the fan shuts off but the fan is internally wired and controlled by the PowerMax converter MBA. So it seems that whatever is drawing the .10 Amps shuts down first allowing the fan to shut off. I can't get a check now because the ambient temperature has dropped 10 degrees from when the anomaly occurred (95+). The sun hits the back of the RV and that is also where the refrig is located so maybe that is linked somehow.
The Bern is offline   Reply With Quote
Old 08-03-2015, 05:52 PM   #32
Originally Posted by Ford1 View Post
If the gas leak detector is powered it activates the propane shutoff valve(solenoid). That could very easily account for the additional current draw. Try turning the detector off. That causes the valve to close and power to the solenoid valve and the control circuit is no longer drawing current.
If you have a powered awning with remote, it too is always consuming some power.
I did disconnect the LP detector and the LP circuit still showed a draw of .!0 Amps.
Old 08-03-2015, 06:00 PM   #33
oldtool2
Originally Posted by oldtool2 View Post
I wouldn't think so but guess anything is possible. Sense the unit is 10 years old who knows what a previous owner did. He may have added a fan that is hot (running) all he time. Turn the fridge on. ID the fuse for it. Shut it off and pull the fuse. This will tell you if it is something on the fridge that is not controlled by the on/off switch.
I am still curious as to why you are concerned about this. Also why you disconnected the battery while on shorepower? What am I missing?
Jim
Bought the unit used and am trouble shootiing everything before I use it. Don't want to wear out the fan on something that I may be able to correct.
Old 08-03-2015, 07:24 PM   #34
Originally Posted by nomad297 View Post
Won't the converter itself draw some power?
Bruce
The converter/charger only draws 120v power, not 12v power. Its purpose is to supply 12v power to recharge the battery AND to supply 12v power for 12v appliances like lighting, propane detector, TV antenna booster, refer control panel, water heater controls, 12v fans, 12v remote control devices, 12v radio displays and memories, and probably a few I've forgotten to mention.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 08-04-2015, 09:03 AM   #35
I really don't think you need worry about wearing out the fan. I understand that you bought this unit used and have no idea what some other owner may have done or why but from what I have seen following this thread it appears to be working properly. All electric or electronic items generate some heat. The fan is controlled by an internal thermostat and it is coming on and off as it should.
I wrote Parallax about a couple of questions I had about my converter. I received a very quick and detailed reply from, I believe, one of their engineers. Here is a link so you can contact them and might be able to get information you are looking for:
https://www.parallaxpower.com/contact
We may have already answered your question. I am sure though that they can verify that. I know I was pleased with their response.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 08-04-2015, 11:33 AM   #36
Reply from Parallaxpower:
"The fan circuit is controlled by a thermistor and is triggered primarily by the amount of heat generated as a result of the DC current the converter is supplying to the DC system while the converter is powered on. In general terms at 70-75 degrees F. the fan will trigger at approx. 20-25 amperes of DC current supplied by the converter. The fan circuit will trigger sooner with a lower DC ampere load if the ambient temperature in the converter mounting location is 80 degrees or higher".
Though I have a different brand converter I have to assume that they are all quite similar, thanks for the lead.
Old 08-05-2015, 09:25 AM   #37
Your quite welcome. Even though I have gotten some excellent answers to my questions here from those that have "been there done that" it still helps to go to the "horses mouth" on occasion.
" The fan circuit will trigger sooner with a lower DC ampere load if the ambient temperature in the converter mounting location is 80 degrees or higher." I think that statement pretty much answers your question about the fan. It is not necessarily the load that triggers the fan. This has been mentioned by a couple of your responders. If the converter warms up for any reason the fan will run to protect the converter. And yes, I would guess they are all designed pretty much the same.
Glad we could help.
Jim
George Bernard Shaw
power
