Old 07-31-2015, 05:02 PM   #1
Unknown circuit with constant power draw.
With the battery disconnected and the RV plugged into 110v the converter's fan will come on after a few hours and continue running. The inside coach temperature has been above 85 deg. In checking each DC fused line in my control panel I have power being used on only two circuits. One goes to my vent fans (.01 Amps) and the other is through a 15a fuse labeled DSI for a total of .18 Amps which is providing power to the LP detector (.08 Amps) plus something else (.10 Amps). I don't know what the something else is. Can someone give me a hint? It seems that the ambient temperature plus the constant .18 Amps is enough to trigger the converter fan so if I can eliminate the extra .10 Amps it may be enough to prevent the fan from turning on.
The Bern is offline   Reply With Quote
Old 07-31-2015, 05:22 PM   #2
Fridge?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-31-2015, 05:50 PM   #3
fonzie's Avatar
DSI = Direct Spark Ignition.....so either fridge or water heater when on propane
Fonzie
Old 07-31-2015, 06:24 PM   #4
Radio Memory?
drc343 is offline   Reply With Quote
Old 07-31-2015, 06:35 PM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
X2 Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-31-2015, 06:37 PM   #6
Might be smoke and CO detectors.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Autostop
DSurette is offline   Reply With Quote
Old 07-31-2015, 07:09 PM   #7
waiter21's Avatar
radio, TV, smoke detector, LP detector, CO detector, Frig control , water heater control, Trik-l-charge, inverters.
Put your ammeter in line then remove the fuses one at a time u til the phantom loads go away
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-01-2015, 11:59 AM   #8
No, not fridge
Originally Posted by Toddupton View Post
Fridge?
I'm not sure if this is how to answer to your comment its my first time on the forum.
The Bern
Old 08-01-2015, 12:21 PM   #9
The Bern
It could be your refrigerator. Is it on?
2016 Flagstaff 23lb
Old 08-01-2015, 01:42 PM   #10
Tom48's Avatar
First I would never run the thing for more than a couple minutes, without a battery in the circuit. The battery evens the load, improves the quality of the current from your converter/charger, which is often fairly ROUGH DC current without the battery as a buffer. Next look at the specs for your converter, you can usually find it on line. Some fans are temp activated, some are current flow activated and I guess some even just run if there is current draw. Decide if what you are seeing is normal or actually a problem.
I agree with the others Re: the FRIG always draws a small current to the digital controls. Most other things like the CO detector and propane detectors use some, but very little power. IF you are worried, check the draw fuse circuit by circuit.
Tom48 is offline   Reply With Quote
power
