Originally Posted by tbritt
Just a question now, but if you replaced the 30 amp power center with a 50 amp power center plus cord and TT plug, would you have to replace all the 120 wiring through out the TT..?? Both centers suppies the same 120 volt.
No wiring inside would need to be replaced, except the feed wire to the panel from the outside. Since you are familiar with 30AMP think of 50AMP this way 2 30AMP feeds and the panel has a left and right 30. So when to connect the internal wiring up you want to balance it between the two sides, if you had 2 A/C units you would put one on each side. That is rally all there is to it.
With the correct adapter you can run a 50AMP system off a 30AMP service (everything in you unit would work except a second A/C) you can even run off a 15 or 20 AMP home service by adding a second adapter, just keep in mind you if you turn on to many things a breaker will trip.
