Old 10-13-2018, 05:42 PM   #1
Head Rambler
Post Upgraded from 30 amp to 50 amp service.
I upgraded our Salem 29RKSS from 30 amp service to 50 amp service.
It was pretty easy. I had to replace the power panel because the original was a WFCO WF8955PEC which is a 30 amp unit only. I took the opportunity to upgrade to a Progressive Dynamics PD4560.
So here's a list of the parts I bought and some Pics of the 30 amp service.
I'll add pics of the 50 amp service later, but it's basically the same except it's cleaned up a lot.
Power Converter PD4560 . . . . . $255.00 (Best Converter)
50 Amp Double Pole Breaker . . . . $9.50 -- (Home Depot)
3C/#6 w/gnd . . . . . . . . . . . . . . $18.84 -- (Home Depot)
50ARVKIT Conversion Kit . . . . . $149.22 -- (Walmart.com)
Camco 50 Amp Power, 25' . . . . . .$77.42 -- (Amazon)
For a Grand Total of . . . . . . . . . . $509.98
Here's the box that I had to coil 25' of 10/3 cable in.
Name:	30 Amp Coil Box.jpg
Here's a view of it with one side removed.
Name:	Coil Box Open.jpg
Here's the cable coiled up with the box removed.
Name:	30 Amp Cable Coil2.jpg
Here's the WFCO Power Panel.
Here's the legend. It's more readable than some I've seen, but the Moitor threw me for a while. And all the light circuits were labelled Lite!
Name:	PP Legend.jpg
Gotta go campin!
Old 10-13-2018, 05:49 PM   #2
Head Rambler
Since I already had a 30 amp receptacle mounted to the shop, and that's all I need at home, I took the Female end that came with the 50ARVKIT and put it on the old 30 amp cable to effectively make a 25' long 30 amp male to 50 amp female twistlock adapter. I took a piece of #10 awg wire from the cord and jumped from X to Y so both legs of the female end would be hot.
Gotta go campin!
Old 10-13-2018, 09:45 PM   #3
I did the same thing last month. It was very easy just a bit time consuming. I hate stripping wires but having many new outlets for electric heaters is awesome!
TranceX2 is offline   Reply With Quote
Old 10-14-2018, 06:04 AM   #4
Head Rambler
I plan on adding a couple of receptacles on a separate circuit, and I'm going to run a wire inside the wall and through the attic for a second A/C in the bedroom.
Gotta go campin!
Old 10-14-2018, 06:48 AM   #5
You might want to recheck your math. Looks like a bit over $500 to be. Nice upgrade!
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 10-14-2018, 07:35 AM   #6
x2 check your math. Unless that's the figute you told your wife so she didn't get pissed.
Kimber45 is offline   Reply With Quote
Old 10-14-2018, 07:42 AM   #7
tom39's Avatar
Attachment 189090
So now I am curious. What does “Moitor” identify?
2011 Rockwood 8288 SS UL
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 10-14-2018, 07:04 PM   #8
Head Rambler
You're right. I messed up the excel formula, and I didn't manually check it before I posted it.
Gotta go campin!
Old 10-14-2018, 07:06 PM   #9
Head Rambler
After a little searching I figured out that it was the water pump! I also figured out which fuse was for which lights. So now they're labeled correctly.
Gotta go campin!
Old 10-14-2018, 07:22 PM   #10
tom39's Avatar
So Moiter = Water Pump.
Not sure how or why, but that is good to know?
50 amp, service, upgrade
