Old 06-23-2015, 07:32 AM   #1
run2jc's Avatar
USB Charger not working!
On our second time out in our Micro Lite, I tried using the USB ports next to the 12 volt car charger outlet but neither one of the USB ports would charge my phone.
the 12 volt car outlet does have power they are mounted together in the same housing.
has any one had this problem? Am I not doing something correctly ?
thanks for your help.
2015 Forest River Micro Lite 19FD.
1999 K1500 Suburban 5.7 ltr 4X4
2002 GMC SIERRA EXT CAB 5.3 ltr 4X4
The Deans Brownsville Texas
run2jc is offline   Reply With Quote
Old 06-23-2015, 07:37 AM   #2
fonzie's Avatar
Most likely not wired properly behind USB port(reversed polarity)
Fonzie
Old 06-23-2015, 07:39 AM   #3
spierce617's Avatar
I have a couple of cords that do not charge my phone but work great for communication. They do make some that will not charge I believe.
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 07-01-2015, 10:12 AM   #4
Same Here
The USB chargers next to the 12 volt stopped working this weekend. It is a 2016 Micro Lite. They worked great for the first 6 weeks and now they don't. I don't think it could be reverse polarity since they were fine to begin with like the original poster. I haven't had a chance yet to pull it apart to see what is going on. All the fuses looked good in the control center. Maybe there is a little fuse behind it...I have know idea. This isn't a major feature, but we got used to it and it was pretty handy for all of today's electronics. Any ideas or insight would be greatly appreciated.
HappyCamperCY96 is offline   Reply With Quote
Old 07-23-2015, 02:51 PM   #5
USB Charger Fixed
OP. I was having the same problem. I took out the usb charger and replaced it with a new one from Amazon for $11. It works great now. While I was at it a replace the 12 volt charger with another USB. So now we can charge four devices at once. I think the charging unit is bad in yours as well.
Old 07-26-2015, 08:30 AM   #6
run2jc's Avatar
Thank you for the response, I pulled mine out last Saturday and determined the same thing. it has 12v in but nothing coming out. I didn't want to get another one from FR, same junk same problem. what brand did you find on Amazon? I will look there today.
Thank you, this is what I love abut this site.
We are better together.
Old 07-27-2015, 09:25 AM   #7
http://www.amazon.com/gp/product/B00...ilpage_o01_s01
XYZ boat is the brand I found. This one has a little LED to tell you if it has power or not which I found useful. I just used the wires from the old unit (cut them near the base) and the provided electric hookups. This site is a great help!
Old 08-14-2015, 11:47 AM   #8
Exactly the same problem. Worked fine then didn't. Checked the wiring. My guess is that the USB part failed since the 12 volt plug works fine.
RStormC is offline   Reply With Quote
Old 11-01-2015, 01:05 PM   #9
TGR
TGR's Avatar
The charging station in the bedroom of my Wildcat didn't work when delivered. The 12 socket worked but the USB chargers did not. My dealer ordered a replacement and had it sent to my home where I installed it. The original one was wired correctly but didn't work, while the new one worked fine.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 11-01-2015, 01:17 PM   #10
Mine works but won't charge two phones at once. Does OK with one but when two are connected it keeps cutting out and restarts the charge process like when you first plug in your phone. Will be looking into an aftermarket replacement before long.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 11-10-2015, 05:35 AM   #11
MNtraveler's Avatar
Could someone explain the coach 12V socket(s)? Is that a convenience connected to the house 12V so you can use it if you happen to have a car charger in hand rather than USB, or is connected to the chassis 12V for when the engine is running not the house power. I assume the former due to electrical separation issues. Thanks!
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
