Old 05-16-2016, 01:44 PM   #11
Vengeance Owner
dwrichards's Avatar
I have been adding 12v gadgets also. Consider getting a few of these to keep on hand:
http://www.amazon.com/Nextrox-Conver.../dp/B00A71CMDU
There are waterproof versions and versions that take a wider voltage range.
2015 FR 29V Vengeance Toy Hauler
2015 Honda GL1800 F6B
2009 Dodge Ram 1500, Total Load Control air bags, Blue Ox Swaypro.
Technology presumes there's just one right way to do things and there never is.
dwrichards is offline   Reply With Quote
Old 05-28-2016, 08:05 PM   #12
It most likely has a switching power supply to generate the 5v for the sub connectors.
Depending on the chip set inside the hub it may not switch on the charging ports until it's plugged into a host and enumerates. Some of them will then continue to support the charging until the 12v is cycled.
Martin
redwolf is offline   Reply With Quote
