Old 04-01-2016, 10:47 AM   #21
B and B's Avatar
I worked with 12 phase systems. That is confusing! Used to generate high voltage 30 kVDC for Television Transmitters. By having all those phases making smooth filtered DC required smaller capacitors and chokes.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-01-2016, 10:48 AM   #22
OntarioFireFighter's Avatar
Originally Posted by ScottBrownstein View Post
First of all, the power pedestal in an RV park (and your house) is always single phase.
I agree with everything you wrote - except the above sentence...
It should be "ALMOST" always single phase... NYC, in a holdover from the Edison/Westinghouse power-war days, actually does deliver 2 phases; and you get 208v hot to hot; 120 hot to neutral.
Otherwise - I think you did a great job explaining the situation!
OP - there are inverters that can be paralleled - but to deliver 50A at 240v, you're looking at 12 kw - assuming a typical 90-ish percent efficient inverter, you're looking at a little over a 1100A as 12vdc... That's not a practical load to try and support. Even at 1/2 load (25A @ 240v) - that's still 550A at 12v.
You'd be better off with a generator, or a pair of paralleled generators (that are purpose built for it, and can cross reference each other's voltages).
Just tying the neutrals of two stand-alone generators together, then letting the hot legs float, can cause all kinds of strange issues...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 04-01-2016, 10:52 AM   #23
Originally Posted by DougP47 View Post
Ok my question is that if you measure access L1- L2 with volt meter would i get 0,120,240? Im thinking im getting 0 with this set up . I have a 30 amp set up at this time but trying to get my head around 50 service for the future. Sorry for the mental block
In a split phase 50 amp system you should always get 240, or something like that between L1 and L2.Then 120 between L1 and neutral and L1 and ground...for L2 as well, and pretty much nothing between neutral and ground (it depends on everybody else who is hooked up if you are at an RV park.) In a 30 amp system, there is no L2.
Most important is 240 between L1 and L2.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 04-01-2016, 10:56 AM   #24
Pickin' & Campin'
In a properly wired 50 amp service you will get 240 volts measuring across L1 & L2.
Feeding a 50 amp service with a 30 amp dog bone adapter you will get 0 volts across L1 & L2.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-01-2016, 11:57 AM   #25
Great discussion guys. But did you notice the OP never came back? I'm sure that folks got a lot of education on the subject, thus it was mucho good!
2017 RAM 3500 DRW CC Laramie, Curt Q20
2013 CC 36CKTS
Me and DW
2 cats: Bello & Dexter (Peanut) RIP
DavandJane1 is offline   Reply With Quote
Old 04-01-2016, 01:38 PM   #26
DougP47's Avatar
5picker thanks understand now.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 04-01-2016, 07:24 PM   #27
Herk7769's Avatar
I sincerely hope he got his answer.
I know I learned a lot from the continued discussion of this topic.
HAM CALLSIGN - KC3FFW
Old 04-06-2016, 09:05 PM   #28
Location: North of I-10 & South of I-94, but East of I-5 & West of I-95
OK...I'm back again, and I did (briefly) read all the stuff. Basically, this is an eye opener as I always believed the 50 amp service was 240 volt multiple phase. However, the diagram definitely explains why my 30 amp gas generator, with a 30 amp to 50amp adapter (dog bone) makes my 50 amp camper work.
At any rate. Because I was under the impression I needed two 120 volt legs phased to run a 14-50R receptacle, and I never found a single inverter which has two separate legs, my thinking was to run two inverters, one inverter per leg. I now know this will not work. However, I have had a solar engineer say it can work if the two inverters are run 180 degrees out of phase? Which makes my head hurt trying to figure that one out.
At any rate, my 6000 watt gas generator has the 30amp to 50 amp adapter, which works the camper with out problems. what really is odd, is last weekend, I actually turned both AC's on at the same time, and they both worked! Again, my head is hurting trying to figure out how that happened with out shutting anything down.
So, my thinking now, is I only need one inverter, and with the wiring modification, I can make the necessary adapter to plug into my camper. With 30 amps, I can certainly run one AC, (which is all I need anyway). When I turn the generator on, the transfer switch takes over, and I can follow my Happy Path...
Thanks for the help
2nd House is online now   Reply With Quote
Old 04-12-2016, 08:47 PM   #29
OK, I’m back again, and again, with a question. First off, I understand the discussion and the areas of 120V measured from one line to neutral, and 240v measured from both hot leads. And I even understand the theory of one line where the electron flow in one direction and the other line with electron flow in the opposite direction, and how they approach zero as they move to the neutral…I think.
Here’s what I’m not following: In the schematic on the first page, where the dog-bone adapter has a jumper from line 2 to line 1, I’m seeing no power to line 2.
If Line 2 has no power (because of the adapter jumper) then how does anything work which utilizes Line 2?
Or, is this the area where the voltage “gets” to line 2 over the neutral as the current moves back-and-fourth as discussed?
Or, is line 2 only used for the second AC only…which doesn’t make sense, as both my AC’s are working with the dog-bone adapter.
Also, on my Generator, the outlet for the dog-bone is a 4 wire 14-50R receptacle, and the decal states 120/240 volt outlet.
Thanks for the help
Old 04-12-2016, 09:14 PM   #30
AquaMan's Avatar
I'm still at a loss as to what you are trying to do with the inverter(s) (an inverter changes 12v dc to 120ac).
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
breaker, inverter
