Old 05-27-2013, 09:13 PM   #1
Question Using Generator in bad weather
I recently purchased a Yamaha 3000 to use with my tt. I know these portable units are not weatherproof. I am wondering how others deal with using their generators during potentially bad weather, especially rain. My tt is not a fifth wheel, so I can't put it underneath. If I am using the generator to run the AC at night and it starts to rain while I'm sleeping, I'm worried about what might happen to the generator or my tt. Are there any suggestions regarding the use of a cover?
roxberrym is offline   Reply With Quote
Old 05-27-2013, 11:12 PM   #2
I have a TT as well, and it is wet out here on the west coast lol. I am running a Honda eu2000, and I usually either set it up under the slide (I can lock it to the wheels and power plug is right there) or just inside the rear bumper underneath with the exhaust facing out. ( i can lock it to the landing jack in this case) it may get a little bit of splash on it, but not seriously wet or soaked.
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 05-28-2013, 12:01 AM   #3
Twisty's Avatar
"...generator to run the AC at night"??
Safe to assume that you are not in a CG?
Make a little "lean-to" and lock it to the bumper or put it under the slide out - if you have one -
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-28-2013, 12:30 AM   #4
bikendan's Avatar
i put our Honda 2000 in the truck bed under the bed cover.
you don't say what tow vehicle you have.
as was said, i don't know of ANY campground that allows running the generator all night.
will you be boondocking?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-28-2013, 03:34 AM   #5
I have a Champion 3500 and I run it in the bed of my F250 that has a snap down tonneau cover covering the generator. The trailer is plugged into the 30amp RV outlet and at the same time I plug in a 115 volt clamp on fan into one of the two 115 volt outlets. I clamp the fan to the frame of the generator to blow air from inside the trucks bed across the cylinder head of the generator's engine back out, along with the exhaust facing outward out the tailgate opening that I keep open.
jamesroadking is offline   Reply With Quote
Old 05-28-2013, 06:00 AM   #6
When I had a Honda 3000 and we boondocked, I used one of those plastic type tarps. I strung a rope between two trees, threw the tarp over the rope, used the grommet holes to tie it down(probably 6 to 8 holes) with tent pegs. The sides were about a foot or so off the ground. At the the part that went over the rope I used two pieces of light rope to hold the tarp in place at each end. The genny never got wet at all. The 30 amp cord was stretched out the maximum distance away from the trailer. I also left the 5 gallon gas container under the tarp as well as there was room. I could walk under the tarp, bending down to fill the genny.
Pipeman is offline   Reply With Quote
Old 05-28-2013, 06:07 AM   #7
Herk7769's Avatar
Generator use in the rain and why it needs to be covered.
That is my inverter control board that got wet while under power.
The repair cost was quite a "shock". (sorry for the pun)
ID:	31513   Click image for larger version
ID:	31514   Click image for larger version
ID:	31515   Click image for larger version
Name:	Generator corrosion 012.jpg
ID:	31516   Click image for larger version
Name:	Generator Corrosion 013.jpg
HAM CALLSIGN - KC3FFW
Old 05-28-2013, 07:43 PM   #8
Thanks for the responses. My tt is a toy hauler that I use boondocking at weekend giant scale model airplane contests throughout the Midwest. I wanted to stay in my own space at the flying fields that I visit rather than using area motels. Running the genny throughout the night won't be a problem. Just seeking ideas on protecting it from the elements. Thanks to all who responded.
2013 FR Grey Wolf 19RR
2012 Chevy Avalanche
Old 05-30-2013, 11:15 AM   #9
ryand's Avatar
I have a 2400 Yamaha that can either fit under the slide out with exhaust facing out or as others have said under the bed cover with tailgate open.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
